need help with ex hubs asap
Old Feb 12, 2009 | 09:50 PM
datnigabluberry's Avatar
Default need help with ex hubs asap
well i went to change the wheel bearing in my knuckle and the bearing ruined the hub can i get it from another car to pop in i tryed majestics website but it wasnt listed help please
Old Feb 12, 2009 | 09:57 PM
Default Re: need help with ex hubs asap
well i just found a site that has it on there gotta call in the morn 140 shipped sucks tho
Old Feb 13, 2009 | 07:53 AM
never mind there discontinued that sux what can i do now
Old Feb 13, 2009 | 09:29 AM
anybody know if i can switch it with something else or am i gonna have to switch everything over to da
Old Feb 13, 2009 | 09:53 AM
4drEF's Avatar
Keyboard Humorist
I think the bearing in the EX is the same as the one in the DA.
IF that is true, then you should be able to use a DA hub.
Of course you would want to measure it against your EX one.
Old Feb 13, 2009 | 10:05 AM
dr_latino999's Avatar
A suitable replacement is the common hub found on all models that aren't splined for HF axles. I documented this problem of discontinued parts back in 2007 as did Wes Van.
Old Feb 13, 2009 | 10:07 AM
is there a replacement i can get i forgot to mention i have an ls in it to
Old Feb 13, 2009 | 10:19 AM
Yes, you push the old EX hub out and use it for frisbee and you press in the new hub. DX/LX/Si all share the same part number and they are the replacement. The difference comes in the size of the rotor support which actually does not affect the dynamics. Maybe heat transfer, but not enough to go "OMG WTF BBQ!?"
Old Feb 13, 2009 | 10:24 AM
i looked em up last night and they were dif but i guess ill check again
Old Feb 13, 2009 | 10:26 AM
yea i just checked the part number is dif
ok nvm i see what you mean now i see the bearings are the same
Old Feb 27, 2009 | 06:04 AM
Wes V's Avatar
http://www.performanceforum.com/wesv...hubs/hubs.html
Wes
Old Apr 10, 2009 | 07:43 PM
K20EF8's Avatar
I have run into a huge problem, just replaced my ex hubs with Si hubs and bearings and my Spoon calipers do not fit anymore. The rotor/hub face has been moved 7.5mm outward, I dont know what everyone else is doing... but this has made me Fkin pissed off. These are all the correct part numbers and the hubs/bearings were pressed in by a honda tech.
Old Apr 11, 2009 | 10:18 PM
Tyson's Avatar
wes lives!
Old Apr 11, 2009 | 10:28 PM
Tyson's Avatar
you did something wrong. be pissed at whoever did the installation. hub probably wasnt pressed in all the way.
jdm206
Feb 12, 2015 10:34 PM
crx_253
Apr 13, 2011 06:42 PM
manuiacoban
Apr 23, 2010 03:45 PM
Eggman
Oct 18, 2005 03:56 PM
cursED
Apr 10, 2004 06:57 PM
