Koni perches, Din pockets, Si parts, Directed Amp and Misc. CHEAP!!
Here is a little winter cleanup of parts that needs to be sold. No reasonable offer refused.
Koni Spring Perches. These werent used since I had to get ground control specific parts from Koni. Brand new never used. $20 plus shipping
Din pockets from the 96-00 Civic. Should also work with similar Prelude, Accord and Integra DIN pockets as well. $10 a piece plus shipping.
Rear Compensator Arm. These arms connect to the front of the rear trailing arm and then to the body which allows for toe adjustment in the rear. The toe adjustment bolts like to seize inside the bushing and its a PITA to replace. These work with all 92-95 Civics and 94-01 Integras. Make it easy and buy these 2 for $20 plus shipping.
Crx Si, DX and HF distributor cap. This is a new OEM Honda part that might have 10 miles of usage on it. Will also work on 88-91 Civic Si EX and DX models. $20 plus shipping including the OEM Honda spark plug wires.
Aftermarket Honda radio harnesses. 2 available both used but with plenty of wire left. $10 shipped per harness.
90-91 Civic/Crx gauge cluster. Worked great when removed. The speedo needle is broken, simple fix. $15 plus shipping.
92-93 Accord Driverside Axle, new from Auto Zone. Never installed. Its been sitting on my "car" shelf for nearly 3 yrs. Its for a 5 spd car and has the bigger outer joint if you are interested in a hybrid axle for your ITR knuckles or K series swap. $15 plus shipping.
Directed Amp with 500 watts bridged. Its an oldie but a goodie. One set of rca inputs doesnt work so everything is heard in mono. Great for bridging a sub. I used it like this in the "weekend toy" for almost 4 yrs. Best offer.
PM is the best way to get ahold of me if you have questions. Please make sure to check my ebay link as well. http://shop.ebay.com/merchant/oncesi...Q_fromZQQ_mdoZ
soclean
Sep 27, 2012 09:21 PM
CRX Lee
May 7, 2003 08:48 AM
