88 harness in 90?
Old Feb 12, 2009 | 07:24 PM
JeeK's Avatar
Default 88 harness in 90?
I got a 1990 dx and a 1988 dx, i had taken out both body harnesses and realized some difference but that was months ago and i cant remember what was different.
i called a shop when i saw some different plugs and the guy told me the some **** was different but i dont remember what
right now i got a 1989 crx si, and a 1990 civic dx, i was wondering if i can use the whole wiring harness from the crx in the civic?
id be using the body harness and the engine harness, and the heater box and push button climate control
i tried searching but came up with nothing, either due to lack of information, or maybe i was using bad keywords
TIA
Old Feb 14, 2009 | 08:25 PM
JeeK's Avatar
Default Re: 88 harness in 90?
ttt
Old Feb 14, 2009 | 08:51 PM
frank_el_tanke's Avatar
i don't see why it wouldn't work... you would obviously still need to keep the civic wiring that goes to the rear of the car, but it should be a go.
Old Feb 14, 2009 | 09:35 PM
welfarepc's Avatar
the cluster wiring is different. be ready to de-pin ****.
im sure there are more things that are different as well.
safe yourself hours of troubleshooting and just stick with 90-91 wiring.
Old Feb 15, 2009 | 01:53 PM
the cluster wiring is diff. but i think all that goes to the fuse box. so if the fuse boxes are all similar it should be ok if not then just swap the fuse box.
Old Feb 15, 2009 | 07:16 PM
JeeK's Avatar
alright cool, i remember there was some difference but seeing i'll be using everythin it might work
the story:
i came across a cheap 89 crx with a obd1 d16z6 swap
and i got a 90 civic dx thats getting a b18
so i was thinkin of swaping the harnesses and using it for my 90..
but i might just buy another ef with blown/no drive train and swap everything from the front half of the crx into the ef
or if i find out it will work 100% in a 90 i might swap it into my buddys 91 which i will eventually own anyways
Hatcheg208
Mar 1, 2016 06:57 AM
JeeK
Mar 4, 2009 06:17 AM
Rightside
Jul 28, 2003 02:20 PM
crew08 (girlygirlracer)
Mar 18, 2003 02:49 PM
