Cams???
Old Feb 12, 2009 | 05:44 PM
Egpower88's Avatar
Default Cams???
Sup ppls.. Im looking into buying cams and wondering if these blox cams are any good??? Im not gonna buy it from this site, but any advice on what type to buy??
http://inlinefour.com/bloxraccam.html
Old Feb 12, 2009 | 05:47 PM
Aquafina's Avatar
Default Re: Cams???
Do not want.
Old Feb 12, 2009 | 05:51 PM
Egpower88's Avatar
Default Re: Cams???
Any advice on other cams?? Jus a stock itr motor...
Old Feb 12, 2009 | 06:00 PM
Egpower88's Avatar
Default Re: Cams???
What about skunk2 cams?? What stage would i wanna go if im planning on upgradeing my cams??
http://cgi.ebay.com/ebaymotors/SKUNK...Q5fAccessories
Old Feb 12, 2009 | 06:06 PM
ACTION JACTION's Avatar
Default Re: Cams???
There are lots of horror stories about Blox cams so stay away from it. Skunk2 cams have a good reputation on here and I run a set as well. Are you planning on boosting or staying NA.
Old Feb 12, 2009 | 06:11 PM
Egpower88's Avatar
Default Re: Cams???
NA. What kind of skunk2 cams you have??
Old Feb 12, 2009 | 06:34 PM
TPB's Avatar
TPB
Default Re: Cams???
As part of your consideration for cams, think about whether you are going to bump compression or not.
Old Feb 12, 2009 | 06:58 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Cams???
I've ran one set of Skunk2's (tuner stage 2) and liked them. Now I am going to be running the pro 3's in my new set up. If your not going to bump compression then don't go higher than tuner 2's. Just my opinion.
Old Feb 12, 2009 | 07:08 PM
jomama's Avatar
Default Re: Cams???
blox cams are just skunk cam knock offs. just keep in mind the more aggressive you go, the more likely you'll need to change the springs. VeeeTAAK, yo.
Old Feb 13, 2009 | 04:19 PM
Racebrewer's Avatar
Default Re: Cams???
Hi,
If you have a Type R motor you can go up to 12 MM lift before needing different springs.
Adjustable cam gears may be helpful to put the power where you want it. Along with that thought, the greater the overlap, the greater the compression loss.
I have a JUN II intake only (lets air and gas in), advanced 6 degrees and that works quite well. With both JUN II cams, the compression loss would cause an overall power dip without a compression increase.
John
Old Feb 13, 2009 | 09:34 PM
Egpower88's Avatar
Default Re: Cams???
Is there skunk2 pro2 cam?? Correct me if im wrong... If remember a buddy told me its better than just stage 2... Any website where ill find information??? Thanks
Old Feb 13, 2009 | 11:01 PM
'00_GSR/R's Avatar
Default Re: Cams???
Do Skunk2 stage 2 tuner cams work well with a stock JDM b18c-R? I want to keep my stock 11.1:1 cp. I plan on upgrading the springs/retainers, and getting the cam gears too.
Old Feb 14, 2009 | 05:53 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Cams???
Yes there are skunk2 tuner series stage 1, 2, and 3. There is also skunk2 pro series stage 1, 2, and 3.
www.Skunk2.com
Old Feb 14, 2009 | 07:32 PM
EG8R's Avatar
Default Re: Cams???
Any of you have experience with Spoon cams? I have found a set and am wondering if they are worth the money spent on them. Thanx
buggsy458
Sep 26, 2003 09:36 AM
B00ST2nR
Mar 1, 2003 01:59 PM
Isaac
Aug 20, 2002 05:52 PM
