Tach jumps up and down, car stalls out?
Old Aug 9, 2002 | 03:13 AM
speedymon's Avatar
Default Tach jumps up and down, car stalls out?
Happened to me first thing this morning. The night before it jumped around at idle. Pull plugs 3 and 4....gas on them both. Could the cause be a bad valve adjustment?
Old Aug 9, 2002 | 05:55 AM
Dutchie's Avatar
Default Re: Tach jumps up and down, car stalls out? (speedymon)
You need a new ignitor.
Old Aug 9, 2002 | 01:16 PM
speedymon's Avatar
Default Re: Tach jumps up and down, car stalls out? (Dutchie)
Do you think a surge of power from a bad shift light install would have caused this?
Old Aug 9, 2002 | 03:55 PM
Dutchie's Avatar
It could have. I know MSD's can kill them sometimes, so I would think a surge like that could do it.
Old Aug 9, 2002 | 04:16 PM
Akira-R's Avatar
could be a bad ground
Old Aug 10, 2002 | 07:09 AM
speedymon's Avatar
Default Re: Tach jumps up and down, car stalls out? (Akira-R)
Ok i switched distros with my friend and the problem disappeared. Now the question is what is the faulty component? The ICM or the coil? The coil resistance seems to be in specs. I'm getting a 2.0 ohms when i should read .6-.8 ohms. Also is the ignitor and the ICM the same thing?
Old Aug 10, 2002 | 02:20 PM
Leb_CRX's Avatar
someone who knows their ****...Dutchie
it's the ignitor
|eb_CRX
VTEC IS UR BEST FRIEND
Oct 24, 2007 04:34 AM
decible01
Oct 12, 2006 01:53 PM
sc300turbo
10
Feb 4, 2005 12:13 PM
JalopySiR
Sep 8, 2004 09:31 PM
nd8ch
19
Nov 2, 2003 10:37 PM
