just bought air fuel meter
Old Aug 9, 2002 | 03:10 AM
95gsr's Avatar
Default just bought air fuel meter
on what color wire opn the sensor do i connect the meter to. also o2 sensor is the on before the cat. right?
thanks
Luis
Old Aug 9, 2002 | 05:41 AM
sutrusu's Avatar
Default Re: just bought air fuel meter (95gsr)
i hope you dont plan on relying on it for your a/f ratio, it's horribly inaccurate.
Old Aug 9, 2002 | 08:24 AM
Aaron M's Avatar
Default Re: just bought air fuel meter (sutrusu)
its at the end of the header, use the white wire.
Old Aug 9, 2002 | 11:06 AM
SIK IN DA HED's Avatar
New User
i dont see why people talk down so much on the a/f guages. what do you expect for $60? if you want something totally accurate, of course you go with one that has an 02 sensor of its own... which usually runs 2-3 times more at the least. for what the a/f guage does... its not bad. it gives you an idea.. not an accurate reading.
Old Aug 9, 2002 | 11:31 AM
Tweakmeister's Avatar
Default Re: just bought air fuel meter (dlplayboy)
for the money it can't be beat.
something like a wideband 02 will run you $800
Old Aug 9, 2002 | 02:45 PM
95gsr's Avatar
thanks
Old Aug 9, 2002 | 06:29 PM
MooreBoost's Avatar
I have an a/f gauge, and it bounces for lean to rich all the time. the book says it supposed to because the ecu is remapping the fuel system for optimal performance and gas mileage. but ive also heard its not supposed to do it from a proffesional vette shop. the gauge bounces CONSTANTLY, whos right?
gmoore
Old Aug 9, 2002 | 06:30 PM
Aaron M's Avatar
Default Re: just bought air fuel meter (gmoore379)
bouncing is normal
Old Aug 9, 2002 | 06:49 PM
ITRTurbo's Avatar
Default Re: just bought air fuel meter (SilverB18C1)
Which is a better place to hook up the A/F meter? the wire on O2 or wire on ECU?
Old Aug 9, 2002 | 07:07 PM
Quik Chris's Avatar
Default Re: just bought air fuel meter (ITRTurbo)
Yeah, I used to have a Autometer A/F gauge. My conclusion is that it's garbage. No matter how much I messed w/ my V-AFC fuel map, it still bounced all over except for WOT, where it would be sorta rich, but not all the way in the Green.
Autometer A/F ratio gauge gets:
Old Aug 9, 2002 | 07:28 PM
Aaron M's Avatar
Default Re: just bought air fuel meter (Midori Shinkansen)
its not the guages fault, blame the o2 sensor
Old Aug 9, 2002 | 07:30 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
DAMN O2 SENSORS!!!
there
Old Aug 10, 2002 | 03:37 AM
New User
Default Re: just bought air fuel meter (dLo GSR)
yup.. definitely the o2 sensor. the guage just reads off the o2 sensor. it bounces like that... but if you punch the gas... it stays constant at WOT.
Old Aug 10, 2002 | 06:46 AM
JeffNA's Avatar
Agreed
Old Aug 11, 2002 | 06:47 AM
95gsr's Avatar
Default Re: just bought air fuel meter (JeffNA)
so should i connect it to o2 or ecu?
chriscool888
Mar 29, 2012 09:08 AM
krysted9354
Jan 24, 2009 06:23 PM
bboysake
Aug 23, 2006 02:04 PM
turbo_b16_ex
Jan 20, 2005 11:24 AM
SHhh__VTEC
Apr 11, 2004 12:18 AM
