brakes locked up
ok, i recently encounter a brake problem on my 92 dx hb....seem like my rear brakes are locked up....i cant drive it cause it would be smoking out the rear and barely moving...can anyone help me with this? btw im totally a noobie to hondas..................im posting this trying to avoid professional mech help....thanks!!!!
If i am correct the DX has rear drum brakes, my thoughts would be either the wheel cylinder locked up or they are adjusted way to tight, but if it just happened suddenly i would check the wheel cylinders first. Have you done anything to the brakes at all recently. Any way you may have contaminated the brake fluid? a blockage in a brake line is a possibility to however a lot less likely.
Yeah, you need to get the drums off and find out what the hell's wrong back there. Is there fluid everywhere? Springs broken? Get in there and let us know
i checked it out best to my knowledge and i couldnt find anything so i took it to a shop. they said it was the hub bearing and seems like they were charging a hefty price(est. $500) to fix it. so now my question is would this be something easily to fix or do?
Probably only a half hour job to change a rear wheel bearing. Part is probably around 50.00.
yea sucks to be you payin so much..dont make thread and then go to a shop, loser..This is for poeple that like to fix things you could have took a picture and put it on this thread and we all could have helped you. Plus i dont think iv ever seen a locked up hub or bearing on a honda ever lol mine have 325 thousand miles on them and theyarent even loose. Oh and where do you live cause i will come over and fix your **** all day long for 500 bucks. NExt time get some help
Now if someone has the info, because i dont have the manual right infront of me. the front wheel bearings are pressed in but are the rear ones bolted in? I cant remember. if its bolted in then thats a piece of cake to fix. Just let us know what you plan to do there is always gonna be someone on this site that can help you and like noodler said you can always go rear disc
Good luck.
quote:500... for 500 you can get a rear disc conversion
for $500 you can get the rear conversion plus new rotors/pads/etc
quote
part is about $115 from the dealer. part# 42200-SB2-025
quote:Now if someone has the info, because i dont have the manual right infront of me. the front wheel bearings are pressed in but are the rear ones bolted in? I cant remember. if its bolted in then thats a piece of cake to fix. Just let us know what you plan to do there is always gonna be someone on this site that can help you and like noodler said you can always go rear disc Good luck.
the rear hubs have a nut that you remove similar to the axle nut. the hub/bearing are one piece
quote
robably only a half hour job to change a rear wheel bearing. Part is probably around 50.00. part is about $115 from the dealer. part# 42200-SB2-025
justseeingifitistaken
Mar 1, 2007 06:56 PM
