sohc zc/mpfi swap
Old Feb 12, 2009 | 12:35 PM
tkda's Avatar
Default sohc zc/mpfi swap
i am putting a sohc zc into my 90 dx hatch and i need to know if i need to rewire anything for the distributor, and if i need a si distributor or if i can use my zc or my dx one.
Thanks.
Old Feb 12, 2009 | 01:06 PM
jlicrx's Avatar
Default Re: sohc zc/mpfi swap
the SOHC ZC wiring is the same as if you were putting a D16A6 in or just converting from DPFI to MPFI - you need to do the DPFI to MPFI wiring changes to your harness, which includes changing the connector at the distributor - you use the ZC distributor
Old Feb 12, 2009 | 01:09 PM
tkda's Avatar
so i will need to pick up si distributor plugs and swap them on my harness and on my zc distributor?
Old Feb 12, 2009 | 01:15 PM
tkda's Avatar
And what other cars could i get the plugs from?
Thanks again.
Old Feb 12, 2009 | 01:34 PM
jlicrx's Avatar
you just need one distributor plug that goes on your harness - you don't need anything for the distributor - 88-91 CRX Si or HF, 89-91 Civic Si, 90-91 Civic EX, 4wd Civic wagons with D16A6 and 90-91 Integra B18A1 all have the same distributor plugs
Old Feb 12, 2009 | 06:42 PM
tkda's Avatar
so get a distributor plug for the harness and thats it? and wire the plug up as outlined in the numerous mpfi swaps.
what if i have the zc harness and zc distributor?
Old Feb 12, 2009 | 09:48 PM
tkda's Avatar
bump?
Old Feb 13, 2009 | 05:46 AM
jlicrx's Avatar
rob the distributor plug from the ZC harness and install it on your DX harness - you have to use the DX harness and do all of the wiring changes to it using whatever pieces (like injector wiring) you need from the ZC harness - you can't use the ZC harness in the DX car
Old Feb 13, 2009 | 10:30 AM
tkda's Avatar
Thanks alot jlicrx, you have been a hugh help.
i am not retarded and i think i knew all of this but i just wanted to make sure.
suspendedHatch
10
Dec 4, 2019 11:56 AM
dailyekhatch
Nov 17, 2007 08:26 AM
roterx7
Feb 18, 2006 03:16 PM
h22_crx
Oct 6, 2005 11:16 AM
