ls turbo crx wont start
Old Feb 12, 2009 | 07:14 AM
91lsturbocrx's Avatar
Default ls turbo crx wont start
I recently replaced the gaskets and seals from the head up on my 91 ls motor in my crx. I also put in a chipped obd1 ecu with obd1 conversion harness, 4 wire o2 sensor, obd1 dizzy and jumper, and dsm 450cc injectors. when I try to start it it gets fuel, great spark, and turns over great, and the timing is perfect but it just won't start it just turns over. Any ideas on what could be keeping it from started? Any help is greatly appreciated, thanks
Old Feb 12, 2009 | 10:11 AM
LSVTEC408's Avatar
Default Re: ls turbo crx wont start
does the ecu have a basemap for the 450 injectors?
Old Feb 12, 2009 | 11:03 AM
yea its set up for everything i have on the motor
Old Feb 12, 2009 | 01:58 PM
I managed to get it running once but it poured A LOT of blue smoke out of the exhaust and then oil starting coming out of where my wastegate bolts onto the header and smoke came out of the top of the header, it looked like exhaust was being forced up instead of going down into the turbo and now it wont start again
Old Feb 15, 2009 | 10:20 AM
black97civic's Avatar
wow that sounds horrible. did u change the headgasket possibley put it on backwards?
Old Feb 16, 2009 | 02:47 AM
I'm almost positive that the problem is the turbo seals and there is shaft play so I ordered a new turbo
Old Feb 16, 2009 | 09:37 AM
LSVTEC408's Avatar
sounds like my friends motor, ended up being a bad turbo. we started the engine with no turbo to see if it did the same and for sure it was blown seals on the turbo.
Old Feb 21, 2009 | 03:44 PM
I got the new turbo bolted on but now it is burning a lot of coolant
tyvtec23
Oct 20, 2011 04:11 PM
slickrickauto
10
Aug 17, 2008 03:57 PM
nelsonb16
Jan 31, 2008 06:41 PM
ys1civic
Nov 24, 2005 04:37 PM
jsull.
Sep 17, 2005 09:36 PM
