Got a Fuel Presure Regulator (FPR) and a FPG and still check engine light goes on!
Old Aug 8, 2002 | 11:32 PM
capcon83's Avatar
Default Got a Fuel Presure Regulator (FPR) and a FPG and still check engine light goes on!
just installed a FPR and a FPG on my R and my check engine light still comes on after i reset it too. dont know what to do and the most my V-AFC did was 11% and it still pulls the code
Old Aug 9, 2002 | 12:02 AM
Darin D.'s Avatar
Default Re: Got a Fuel Presure Regulator (FPR) and a FPG and still check engine light goes on! (capcon83)
take out the vafc and sell it..if that doesnt work make sure your fuel pressure regulator is installed properly. what does the fuel pressure gauge read at idle?
Old Aug 9, 2002 | 01:46 AM
PYITR821's Avatar
What mods do you have done to your car? What is your fuel pressure with the car running, vaccum line disconnected and pinched off?
I live in Marysville about 45 miles north of Sacramento, do you ever go to Sacramento Raceway? I am going there this Saturday to watch the CMI's.
Old Aug 10, 2002 | 12:24 AM
capcon83's Avatar
Default Re: Got a Fuel Presure Regulator (PYITR821)
i go to sacrametno race ways every wensday but not on saturday and at idle my pressure is 41 1/2
if u go on this wensday i will be there
Old Aug 10, 2002 | 02:04 AM
PYITR821's Avatar
Default Re: Got a Fuel Presure Regulator (capcon83)
Do you have more aggressive camshafts? If you do I would up my FP to 48psi. Stock FP is about 41psi, I think your FP might be kind of low if you are running more aggressive cams. You would have take away some fuel with the VAFC though if you are running the higher FP.
[Modified by PYITR821, 11:06 AM 8/10/2002]
Old Aug 10, 2002 | 10:00 AM
capcon83's Avatar
i have spoon camshafts
there mild cams
HyperFlow
May 15, 2010 06:28 PM
91integraLSVTEC
16
Mar 7, 2004 07:16 AM
Red Rocket
Nov 4, 2002 11:19 AM
10seconds
Jul 15, 2002 02:00 PM
MrSmith
Feb 7, 2002 08:16 PM
