What's your B16A header + b-pipe + exhaust setup?
B16A Only Please!
Vote on one of the following setups, or add your own setup if you think its good, also give your reasoning too, thanks!
[Modified by skafia, 12:21 AM 8/9/2002]
Right now I have DC 4-1 headers, high flow cat with 2 1/4 piping.... It works great for b16, has some back pressure for low end, but it opens it up a lot for high end.
However, when I finish upgrading everything else I will go back and change it from that to JDM Type R header, same cat, and 2 1/2 piping... I now have the LS/VETC so I need a wider opening....it needs to breath damnit!!!!!!!!
I dont know why this is a poll, there are tons of combinations. I have a jdm 4-1, spoon cat-jack, ctr b-pipe and a spoon n1 muff.
I just want to know what different setups are good... what size piping are you using? Ah.. the stock CTR B-pipe, what size is that anyway?
b16 motor
USDM ITR exhaust manifold
gsr midpipe
custom cat replacement(the length is really screwy with my setup)It's not the legth of a normal cat replacemnt
mugen rear section
gsr midpipe
mugen rear section
hrm, so with the USDM ITR exhaust manifold... you get the low end torque as opposed to the JDM 4-1....
I didnt feel a loss of torque when I went from a usdm itr exhaust manifold to the jdm itr manifold. But I did feel gobs of top end. But I guess it depends on the setup.
[Modified by WAFFLES, 2:34 PM 8/9/2002]
Better than the USDM ITR manifold.. and this is the JDM B16 Manifold.. isn't it better than the USDM B16 Manifold?
You're saying that the USDM ITR Manifold is better than the JDM 4-1....and I was confused...
I'm asking is the JDM B16 SIRII manifold better than the USDM B16 Manifold?
DC JDM ITR header, SMS 2.5" cat, custom 2.5" b pipe (mandrel bent), Type One axle-back.
Works good, sounds good.
[Modified by EKology, 2:05 PM 8/9/2002]
Ooooohh...im dying for a sound clip!!!
. It does sound nice though, a bit loud sometimes (there is no resonator) but that's what the silencer is for.And 6ghatch: Nice exhaust!
And I'm pretty sure the USDM and JDM b16 manifolds are the same.
unknown0001
10
Feb 13, 2006 11:32 AM
