Weird power door lock issue...
I have not popped off my door panel to investigate yet, but I have this issue with my driver's side door.
If I lock the doors with the passenger side switch, it will lock both (driver/passenger).
BUT, if I use the switch on the driver's side, it will lock the passenger side, and MOVE the driver's side lock, but it won't lock it.
However, if I have the door open and I lift up the door handle and press down on the driver's lock switch, it will lock both...??
Anyone have this experience/know what's going on?
NOTE: The car was broken into in the past (I bought the car this way) and I can't put the key into the outside "tumbler." I see something metallic stuck/broken off in there so I can't open the driver's side from the outside. I will try to get it out with a magnet soon.
That doesn't make any sense though. If I am sitting in my car with both doors closed, the driver side switch will only lock the passenger lock. If I use the passenger lock though, it will lock both.
This is the first Honda (Acura) that does this. In all my other cars, the driver's side switch would lock both.
i tried pushing the lock itself to the locked position but it acts like the rod is bent or jammed, also i noticed that if i unlock the pass door with the key it unlocks/locks both
breckrider
Honda CR-V & Element
Jan 29, 2018 02:22 AM
portaman03
Honda Civic (2001 - 2005)
Apr 8, 2007 11:04 AM
