Spark plug holes stripping...help needed
Old Feb 11, 2009 | 05:12 PM
turboedsupe's Avatar
Default Spark plug holes stripping...help needed
So long story short friend was helping me at the track and got the #4 plug either too tight or off track. It threads in but when it goes to tighten down it goes tight then loose but not like blownout loose. Im not touching it until i figure out the best way to handle this.
Old Feb 12, 2009 | 03:42 PM
standbackimapro's Avatar
Default Re: Spark plug holes stripping...help needed
your gonna have to take the plug out if it isnt already, take a look at the threads they might not be that bad, you can get a rethreader, like these
http://www.mytoolstore.com/kd/kdengi11.html
It may have stripped because when the engines hot the metal expandsm and when you take the plug out the metal starts to shrink.
You can try the rethreader tool first, then you might have to put a heli coil in
Old Feb 15, 2009 | 10:04 AM
black97civic's Avatar
thats y you dont take plugs out of an aluminum head when its hot autozone has reathread kits.
Old Feb 15, 2009 | 04:01 PM
cockerkid008's Avatar
Ok, then why are you supposed to do a compression test when the motor is at operating temperature?
OP take a look at the threads in the head, its either gonna have to get it rethreaded or a new head
Old Feb 15, 2009 | 04:10 PM
Colt Seavers's Avatar
Use a thread chaser... Just put alittle lube on the thread's to catch the shavings from falling into the cylinder...
Old Feb 15, 2009 | 09:00 PM
slomofo's Avatar
GDD Member
Run thread chaser through, if not then pull the head (unless you can somehow manage to fit an insert kit in there).
Old Feb 17, 2009 | 06:25 AM
jewjew bean's Avatar
you're not suppose to. compression tests are for the tooner boys who think it's a end all be all test of engine condition. operating temperature will have little effect on results.
triskpin
Aug 13, 2014 05:35 AM
john457
Mar 12, 2007 06:03 PM
TQuach
Nov 24, 2005 10:28 PM
HypnotikEFX
May 2, 2005 09:11 PM
arielb1
Jul 24, 2004 10:24 AM
