Need Advice for my 80,000 mi. B18B1
Old Aug 8, 2002 | 10:35 PM
LS702's Avatar
Default Need Advice for my 80,000 mi. B18B1
I just bought a 96 integra LS with almost 80,000mi. In the future i plan on getting turbo but im wondering if my motor has to much mileage. What should i do to make sure my engine can safely withstand FI? your suggestions are greatly appreciated.
Old Aug 9, 2002 | 06:16 AM
LshatchTurbo's Avatar
New User
Default Re: Need Advice for my 80,000 mi. B18B1 (LS702)
Run a compression test, and possible a leak down test. If the numbers are good, go for it. When i Got my LS engine, I had the same thoughts as you since mine had 80000 miles ticking as well. I also went ahead and changed the timing belt and water pump. This is a piece of cake if your engine is already out.
Old Aug 12, 2002 | 02:28 AM
LS702's Avatar
Default Re: Need Advice for my 80,000 mi. B18B1 (lshatchturbo)
thanks dude.
Old Aug 12, 2002 | 05:53 PM
sjk's Avatar
sjk
I would start saving your money.have you ever seen a blown piston on a ls with turbo.Plan to install pistons/rods with bearing/block guard and head studs.This will beef up internals to hold quit a bit of boost.
ps don't forget timing belt and water pump.
B18B1-Crx
Jun 18, 2011 07:59 PM
just-ef-it
Jan 4, 2011 09:24 AM
GsrTurboCRX88
Jun 5, 2006 07:44 AM
HybriDNA
Feb 8, 2003 12:28 PM
spettinger
Feb 1, 2003 12:49 PM
