B18c1 or b18c5
Old Feb 11, 2009 | 03:30 PM
95GS-R801's Avatar
Icon2 B18c1 or b18c5
Ok i wanna do a b18C5 swap in my gsr but i wanna know if it would be worth spending the money.. because i dont wanna spend the money if im not going to notice a difference in performance thats worth it.. also if i go through with it i wont be doing anything to the car for a while but when i get the funds will it be better for a all motor build over the b18c1...i just need some helpfull opinions on which to go with
thanks
Old Feb 11, 2009 | 03:33 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: B18c1 or b18c5
If your going to want an all motor setup and leave it stock then go with the b18c5.If you want to build the motor then go with the b18c1,simple as that.Depends on your budget too.
Old Feb 11, 2009 | 03:35 PM
Vietnamese!
You should do some research of which 1 fits you the best though.
Old Feb 11, 2009 | 03:40 PM
95GS-R801's Avatar
idont think i would really do anything to the internals of the c5 if i got it besides the head
Old Feb 11, 2009 | 03:42 PM
95GS-R801's Avatar
and another thing is that my rings are goin out so i would most likely have to rebuild my c1
Old Feb 11, 2009 | 03:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You could probably make as much or more power than a C5 using your C1 and a few mods like cams, valvetrain, intake manifold, chipped ECU and tuning, for less money than the C5 swap.
Old Feb 11, 2009 | 03:49 PM
Vietnamese!
yep.
Old Feb 11, 2009 | 03:53 PM
95GS-R801's Avatar
yea thats true the thing is tho like i said above my rings are going and the c1 needs a rebuild and after rebuild i wouldnt have money to fund all the things to get the c1 in the same power range as the c5 when i could spend just as much and get the c5 swap with more power if that makes sence or i dont know what im talking about ha... and i wouldnt be doing the rebulid it would be from a repituble shop
Old Feb 11, 2009 | 04:05 PM
Vietnamese!
a c5 swap is a 4K swap if you have the money then do it.
Old Feb 11, 2009 | 04:09 PM
racebum's Avatar
a c5 swap is really really hard to find. the jdm b18c ITR is easier to come by and makes slightly more power. $3500-3700 shipped is the going rate for a 97 engine/trans combo. $2800 will get you the engine.
Old Feb 11, 2009 | 04:11 PM
95GS-R801's Avatar
do you think it would be worth spending the extra money to get a c5 over a rebuilt c1 tho???
Old Feb 11, 2009 | 04:57 PM
Vietnamese!
no
Old Feb 11, 2009 | 05:04 PM
95GS-R801's Avatar
well if i rebulit my c1 one i was thinking of getting portflow head with skunk2 stg2s with stock bottem end and bolt ons ect do you think i would get decent numbers....i would appreciate all the help i could get im teaching myself all about this stuff on here as much as i can i dont have anyone in my area the i know that could help me with a all motor build cause all the one shop in my area is not very repituble... thanks
Old Feb 11, 2009 | 07:05 PM
Vietnamese!
All i gotta say is search,thats all.
Old Feb 11, 2009 | 07:24 PM
So FReSh's Avatar
it really just depends on your budget and what goals you have. if you want less of a headache and got money. get a 98 spec b18c. 4300-4500 on average for a complete swap. or else you can rebuild your b18c1 and be able to put down decent numbers too.
Old Feb 11, 2009 | 09:11 PM
xionl1350's Avatar
I think you should rebuild your gsr motor and learn to do it yourself. Eventhough it make take a crap load of time to get everything right. It'll be a great experience for you.
Old Feb 12, 2009 | 12:56 AM
KILLAB17VTEC's Avatar
Genetically Gay
K20a-r
Old Feb 18, 2009 | 11:55 PM
LiEkjAi's Avatar
with 3-4k of getting a c5, u can use the money and build your c1 into a beast
Old Feb 19, 2009 | 01:39 AM
blkb18's Avatar
If you are going to rebuild and plan on skunk 2 stage 2's you might as well go with higher compression pistons while your in there. Just my 2 cents.
Old Feb 19, 2009 | 06:12 AM
hmoobhero's Avatar
if you're taking it to a shop, then maybe you should just get the itr swap. but you can rebuild the gsr to make it faster than the stock itr. you said your rings are bad rite so just put in itr piston, it will bump up the compression. since you're in the block already get a ls crank and rods for the extra torque. also, since the head is off put in the skunk2 stg 2 cams you wanted but you will need to get springs and retainers. but after all this you will need a tune. anything you do internally needs to be tuned. theres soo many things you can do, it really depends on you and how much money you have to spend. i say with this setup you'll spend around 2.5K.
unless you really want the itr engine for the name then get it, but it seems like you want more power so i say rebuild the gsr. gl man.
Old Feb 19, 2009 | 09:18 AM
civicgsr499's Avatar
i say either build ur gsr or get a an ls longblock, preferrably jdm (most likely less miles), and piece together ur own turbo kit and run like 8 lbs on the stock motor. ls+gsr tranny+boost=mad nice setup
Old Feb 19, 2009 | 09:22 AM
kulo's Avatar
gsr
p30/p73 pistons
cams
Old Feb 19, 2009 | 09:56 AM
twentyhurtz's Avatar
JDM b18c + headwork
Old Feb 19, 2009 | 09:59 AM
Yea really, no joke! The local junkyard sells any motor out of any car for 165 plus tax and another 65 for the tranny. A guy i know here went and found a b18b, got it for 250ish, bought a 92 civic sedan for 500 bux, and slapped together a turbo kit - maybe spend 1000 dollars, and it runs 13.4's consistently in the quarter, he tuned it really good though, so he spend about half on his whole care and motor and turbo kit then your thinking about spending on a b18c5
95egGold
25
Aug 12, 2007 02:26 AM
95egcivic
Mar 18, 2007 07:55 PM
thatwhiteguy
Jan 22, 2007 10:33 AM
91 ZC hatchback
Apr 22, 2005 09:12 PM
TEALmobile
27
Dec 12, 2002 08:21 PM
