well i pressure tested my setup today....
Old Feb 11, 2009 | 12:45 PM
turbo boost's Avatar
Default well i pressure tested my setup today....
well today i presure tested my setup and found some leaks around clamps/couplers...then found leaks around all the bolts that hold the compresser tite...so i put teflon tape on them ,sealed them up....now the only leak i have is around the compresser housing were it mates against the backing plate,its not a big leak but there is air leaking around it,is this normal?...anybody eles find this? is there anyway to fix it?
thanks
Old Feb 11, 2009 | 01:03 PM
CRXdan's Avatar
Default Re: well i pressure tested my setup today....
There shoudl be a thin o ring on the backplate if you remove the compressor cover.
Old Feb 11, 2009 | 01:14 PM
humm,i dont recall seeing any rubber o ring?..its a garrett 60-1 with a to4s cover if it matters .70ar
Old Feb 11, 2009 | 01:27 PM
TiAL's Avatar
it's normal, no worries
Old Feb 11, 2009 | 02:10 PM
ok i wasnt sure...just wanted to make sure
Old Feb 13, 2009 | 01:24 AM
Boosted_B_Series's Avatar
How exactly did you pressure test everything? Pressurize the turbo's inlet?
Old Feb 13, 2009 | 03:41 AM
HiProfile's Avatar
There is at least 2 common types of seals that i've seen. A giant o-ring is the newer version that remains 'clockable' for a long time, the other much older type is a flat carbon ring seal. That usually sticks like any other gasket over time, breaks apart, and needs replacing. In this situation, a tiny bit of silicone will work, although the gaskets are all of $3-5 from ebay. You don't have to worry about that relatively small leak, especially since it seals a tad more when hot - but every small amount can help. The leaks that make a big difference are the ones that leak a good 5% or more. That would make your turbo run that much higher in the efficiency map, which is usually bad.
Old Feb 16, 2009 | 10:44 AM
ok thanks...yes it is just a small leak enough i could hear it...and true it will titen up a bit when warmer
yes i hooked a line from the air compresser and slowly put the psi up...untill i had it up to roughly 25psi on the boost gauge..figured thats high enough,ill never go that high of boost
TommyC83
May 29, 2010 03:43 AM
sundownz
Jan 17, 2007 06:51 AM
pwrofdrm
Mar 21, 2005 07:06 PM
pwr2lbs
20
Nov 30, 2004 03:45 PM
Canuk_SiR
Sep 21, 2003 11:59 AM
