My suspension.....
Old Feb 11, 2009 | 11:40 AM
98DC4's Avatar
Icon3 My suspension.....
....i believe is f***ed. This morning i made it to work and i went to back out to fix my parkin job and all i hear is a nasty a** noise. So i put it in first and there it is again. Anyways had time to check it at lunch and my front driver side is messed up. It has lowering springs w/o the camber kit so im thinkin maybe that was the cause. At this point im stressing cuz it looks bad. Sorry i kno it isnt a question i just had to vent...
Old Feb 11, 2009 | 04:15 PM
AllMotorDC4's Avatar
Default Re: My suspension.....
I'm on Coil-Over sleeves on stock struts w/out a camber kit. And i'm fine. .Nothing hapopened. .YET :x
haha
Old Feb 11, 2009 | 04:53 PM
thabao's Avatar
Ok sweet, now please define messed up? like is it dumped to the point where the tire rubs on the wheel well and the other side isnt?
are you lowered on stock struts still?
Old Feb 11, 2009 | 07:39 PM
98DC4's Avatar
Tokico blues with i believe egay coil overs.....well my ball joint popped out or w/e and i broke an axel. Also found out some other ****. No motor mounts or some ****. I was told my engine is loose.
Old Feb 11, 2009 | 08:16 PM
I have the same exact problem with my motor. .I think my lower motor mounts are loose or bad. It's annoying if i downshift and or push the clutch in it feels like my motor moves and makes a "thump" noise.
Old Feb 12, 2009 | 08:30 AM
98DC4's Avatar
^^^ how long have u been drivin the car this way? the told me to swap my engine n then started giving me sh** bout my suspension. what should i do? should i sell?
Old Feb 12, 2009 | 09:12 AM
mouab18c1's Avatar
how did you brake your axle?..or did you mean torn boot?
Old Feb 12, 2009 | 09:18 AM
I've been drivng my car for about a week now.i don't beat on it because i'm scared to lol. and i granny shift. I take it real easy. . and DON'T SELL!!
Old Feb 12, 2009 | 01:35 PM
98DC4's Avatar
Idk pot holes on the way to work most likely. Not the boot.....so what should i do? Jus do a swap?
Old Feb 13, 2009 | 06:44 AM
mouab18c1's Avatar
just replace that side of the suspension...less work then doing an entire motor swap
Old Feb 13, 2009 | 01:36 PM
98DC4's Avatar
Replaced the axel already. I was told that my engine was loose and that i had some stripped bolts so that itd be better to swap cuz id have to take the engine out to fix the stripped bolts to begin with...oh and another thing if i have tokico blues, can i use stock springs? ( i now silly question but i was told some dumb sh**)
Old Feb 14, 2009 | 07:51 PM
98DC4's Avatar
Anyone? Lol
Old Feb 17, 2009 | 06:41 AM
mouab18c1's Avatar
yea you can but its kind of pointless
Old Feb 17, 2009 | 06:49 AM
laocivic's Avatar
where ever you went is just trying to sell you another swap.....fix the suspension and get the holes retapped...
icucnme
Jan 28, 2010 02:59 PM
brewcity
Suspension & Brakes
May 16, 2007 04:57 PM
vgsr
May 29, 2005 09:26 PM
insomniac791
Jan 13, 2005 06:01 PM
jas0n
10
Aug 26, 2002 04:43 PM
