SMOKE from Exhaust.
Old Feb 11, 2009 | 08:34 AM
db8int3gra's Avatar
Default SMOKE from Exhaust.
Its two days now that my car been smoking.....it only happen in the morning. 60 degs. in the morning. But later on in the day....I don't see it. Is it normal? Also, I notice that my exhaust shoots out a lot of air......but it doesn't when I start it from a cold start.....after driving it for miles.....there is a lot of air I can feel shooting out.
Old Feb 11, 2009 | 09:12 AM
joelmatt89's Avatar
Default Re: SMOKE from Exhaust.
I have seen this topic posted multiple times this week alone try doing a search, are you throwing any cels, what color is the smoke
Old Feb 11, 2009 | 09:30 AM
db8int3gra's Avatar
Its white in the mornings. And it shoots out almost can't see it.
Old Feb 11, 2009 | 09:49 AM
joelmatt89's Avatar
First, do you live in an area where it is cold sometimes it will seem like it's white smoke if it is cold out, after getting that out of the way, the next thing is are you going through any of your fluids more than normal, especially coolant, white smoke usually indicates coolant, but im not sure if it would go away like that. I don't know of anything that would cause your exhaust to "shoot out" do you normally observe your exhaust this much ie. what are you comparing this to
Old Feb 11, 2009 | 09:50 AM
recycled air 90's Avatar
If the smoke is a thick white color you might wanna check your headgasket. Keep an eye on the temperature gauge and coolant levels.
Old Feb 11, 2009 | 10:01 AM
db8int3gra's Avatar
If I look at my coolant level....it goes down..it used to be at full but usually it normal for it to go down a little? Right?
Old Feb 11, 2009 | 10:07 AM
db8int3gra's Avatar
Now its getting cold in my area in the 60s but in the afternoons I don't see the smoke. What I meant for the exhaust to shoot out is. It has a rush of air....instead of it being normal and steady, the exhaust rushes out air kind of like when u rev the engine. And I have not gone through fluids.
accord_raffi
Aug 20, 2008 02:11 PM
Mechman456
Honda Civic (2006 - 2015)
18
Dec 2, 2007 09:04 AM
Bruce Banner
Feb 16, 2007 05:59 PM
redDAinteg
Jan 9, 2006 04:57 PM
IntEGNYC
Nov 15, 2002 08:13 AM
