Fitment question for an 07 accord
Hey I was wondering if these wheels from an S2000 will fit an 07 Accord Se V6 (4 door)
the wheel specs are:
Fronts: 18 x 7 +42
Rears: 18 x9 +60
Bolt pattern 5x114.3
Here are pics of the wheel if you need them for some reason.
http://www.mnsportcompacts.net/forum...ad.php?t=76840
Fronts: 18 x 7 +42
Rears: 18 x9 +60
The staggered fitment used by the S2000 doesn't work well on an Accord. In addition to the rubbing problem that Opossum Jenkins mentioned, the different widths and offsets are a problem for the Accord. Another problem is the center bore, the diameter of the big hole in the center of the wheel. The S2000 uses a different center bore, front vs rear, and this is a problem for the Accord, which needs the same center bore. Stick with wheels made for Accords or Preludes, not S2000 wheels.
Ah ok thanks for the help. I actually have the S2000 and had a guy with an 07 accord interested in my wheels. I just wanted to see if they would fit so that I could let him know, and others who may be interested in my wheels know.
Thanks for not replying with the typical "do a search newwwb"
EGPrelude
Jul 7, 2008 10:33 PM
sleeperaccordv6
Mar 28, 2002 01:13 PM
