OEM 15x7's
Old Feb 10, 2009 | 04:30 PM
Mr. EJ1's Avatar
Default OEM 15x7's
Which OEM wheels come in 15x7? Im looking for a set cuz my car came with some old enkei's and i really dnt like them. Willing to trade or somthing if interested but i jus wanna get some OEMs n use my same tires. Thanx
Old Feb 10, 2009 | 05:08 PM
r.wright's Avatar
Default Re: OEM 15x7's
no 15" honda/acura wheels came in that width well at least the ones in 4x100 that is
Old Feb 10, 2009 | 09:59 PM
Mr. EJ1's Avatar
Damn so i would have to get different tires, i couldve swore Si's where 15x7. Well thanx anyway
Old Feb 10, 2009 | 10:27 PM
It Wasn't Me's Avatar
They're 15x6
The only x7's, that I know of, are 16" and above.
Old Feb 11, 2009 | 12:11 AM
r.wright's Avatar
whats the size tire you are running right now ? if it's a 15" ( ie 195/55, 205/50, 195/50) already then i doubt you would need to change them.
and yes, the 15" gs/se integra alloys and 15" si civic alloys are all 15x6
Old Feb 11, 2009 | 09:33 AM
nsxtasy's Avatar
H-T Order of Merit
Yup, 15x6 will work fine for most tires used by most Honda/Acura cars, including the 195/50-15 tires normally used by a '92-95 Civic EJ1.
Old Feb 12, 2009 | 09:29 AM
Mr. EJ1's Avatar
Really? My tires are 195/50R15, basically 15x7.
Old Feb 12, 2009 | 02:03 PM
nsxtasy's Avatar
H-T Order of Merit
I'm not sure what you mean "basically 15x7". The 15x7 refers to the diameter and width of the wheel, not the tire. And it's measured at the bead, where the inner edge of the tire seats. If you measure the outer edge of the lip of a wheel, it's usually about an inch larger than the nominal dimensions at the bead; for example, on a 15x7 wheel, if you take a tape measure on the outer lip, the diameter will be around 16" and (if there's no tire mounted on it) the width will be around 8". But it's still considered a 15x7 wheel.
Most 195/50-15 tires can be mounted on wheels from 5.5 to 7.0 inches wide, which is why they are just fine on 15x6 wheels.
Old Feb 12, 2009 | 03:31 PM
SportEL's Avatar
What are the advantages of a 15x7 rim versus 15x6 when mounted with the same tire size?
Old Feb 12, 2009 | 04:39 PM
nsxtasy's Avatar
H-T Order of Merit
Not much. The big difference is looks - and most people would never notice the difference in looks between 15x6 and 15x7. And even among people who would, you'll probably find more people who think that the normal-fit look of 15x6 looks better than the stretched look with 15x7.
For autocross and racetrack use, there's a practical benefit. Some people roll their fenders and put on superwide 225/45-15 tires - R compound track tires, like Hoosiers - for competition use. Tires that size need to be mounted on rims at least 7 inches wide.
But for street use with street tires in street sizes, there's no significant practical advantage.
Old Feb 13, 2009 | 12:17 AM
Mr. EJ1's Avatar
Damn i didnt know that, i jus figured that a tire that is 7 inches wide would be to big for a rim the is 6 inches wide. Thanx!
Old Feb 13, 2009 | 03:27 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i just odered a x7 rota wheel for my 225/50 15 drag radials 40offset. i noticed a difference in the inside of the wheel. It was deeper.
Old Feb 14, 2009 | 05:21 PM
SportEL's Avatar
If stock was 195/55/15, would 205/50/15 be better for a 15x7 wheel, or is it not even worth the extra weight and change in speedo?
Old Feb 15, 2009 | 01:44 PM
nsxtasy's Avatar
H-T Order of Merit
You can use either one; the differences are mostly minor. For example, the change in the speedometer and odometer is 1.6 percent, which is small. Any differences in weight and performance are also likely to be small. About the only difference that's not likely to be small is the availability and price of tires. Some tires come in only one size and not the other. Some tires come in both sizes, and of those, some are cheaper in 195/55 and others are cheaper in 205/50.
Falloutkid90
Dec 1, 2015 08:26 AM
dns92civhatchcx
Oct 5, 2012 06:59 PM
DADOHCturbo
Feb 28, 2012 09:26 PM
JDM C.A.R
Jan 21, 2010 08:08 AM
BinMop
Sep 26, 2007 07:22 AM
