Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
OEM Factory Spoiler Removal
Old Feb 10, 2009 | 03:31 PM
EM2_PLo's Avatar
Icon6 OEM Factory Spoiler Removal
I'm planning to take the oem spoiler off and i need some assistance ... I know you remove the four bolts and lift it off the trunk, but what should i do with the wiring? do you guys recommend i cut it ? hit me up... thanks
Old Feb 10, 2009 | 03:36 PM
Harlowe's Avatar
Function>Fashion
Default Re: OEM Factory Spoiler Removal
No don't cut it. Follow the wires down the trunk arm thing. There will be a plug under where the rear deck 3rd brake light is.
Old Feb 10, 2009 | 03:45 PM
EM2_PLo's Avatar
thanks... is this the same for the 05 model?
Old Feb 10, 2009 | 04:15 PM
Harlowe's Avatar
Function>Fashion
I don't see why it would be any different.
Old Feb 10, 2009 | 04:41 PM
SGolub's Avatar
You can get some rubber plugs to seal up the holes left by the bolts. Hit those with some touch-up paint if you want a cleaner appearance.
Old Feb 10, 2009 | 06:01 PM
EM2_PLo's Avatar
Thanks Do you know the name of the plugs?
EM2_PLo's Avatar
Thanks man... i appreciate it
Old Feb 10, 2009 | 06:20 PM
SGolub's Avatar
I'm not sure, but you could probably find something usable at your local hardware store. Anything that fits the diameter of the hole should work.
Old Feb 10, 2009 | 06:23 PM
Harlowe's Avatar
Function>Fashion
-2 packs of nylon 5/16 inch hole cover plugs from lowes or home depot
-1 box of 7/16 inch rubber O-Rings
- Maybe a hot glue gun
Should looks something like that when finished.
Don't worry about anything leaking, since the holes are on the gutter anyway. Nothing will leak into the trunk.
Pictures and info from http://forums.clubrsx.com/showthread.php?t=556035
Old Feb 10, 2009 | 07:12 PM
EM2_08's Avatar
or you can be cheap and put electric tape over the holes
Old Feb 10, 2009 | 07:15 PM
EM2_PLo's Avatar
Thanks!!! that's perfect!!!
Old Feb 10, 2009 | 08:18 PM
Harlowe's Avatar
Function>Fashion
No problem
Old Feb 10, 2009 | 09:47 PM
ejLday's Avatar
wiring is plug and play, easy to remove
Old Feb 11, 2009 | 12:10 PM
EM2_PLo's Avatar
I tried looking for that wiring you guys were talking about that connects to the third brake light inside the car... couldn't find it ... can any of you send me a pic of where it's located and what it looks like... thanks
Old Feb 11, 2009 | 12:51 PM
Harlowe's Avatar
Function>Fashion
This is how mine is. Pull out the part that is circled, and there should be a plug.
crazyhouse2011
Mar 16, 2013 04:00 PM
Cap'N Chronic
18
Feb 17, 2012 06:26 AM
hi mom
Mar 25, 2005 02:12 PM
MrIllegalX
Oct 9, 2003 10:50 PM
