14 X 5 wheels
Alright i just put Snow tires on my car, work awesome. I need to put regular tire on when it isn't snowing, so i don't ruin tread on snow tire and also increase gas milage on car. Think i took a hit on that with snow tires, it makes sence.
New steel wheels are expensive new. like 50 a piece. I went to the junk yard anticipating i would find another honda accord. No luck.
My question: is another 14 x 5 wheel with four places to put lug nuts compatible with the honda. common sence would tell me yes, but i'm not sure. I found a few 14 X 5 with 4 lugs laying around. this would only be 15 dollars a wheel, maybe with a tire.
Thanks for your help
114.3mm x 4 Bolt pattern (4.5" x 4) as measured center/center between opposite lug studs.
For all accords later than '94, the 14' rim is on the small size, available on the DX only. That's why they're soo hard to find.
There are other considerations:
Offset
Center hole diameter.
etc.
Stick with Honda Rims
Have your auto recycler put an inquiry out on his locator service. They should be able to scare something up for you that way.
Dang, P Adams - you sure know your stuff. All that off the top of your head?
My 96 Accord DX has the 14" wheels. I'm hoping to replace them with 15" or 16" rims. I assume I need to find 114.3mm x 4 (4.5" x 4) equivalent rims to replace mine?
Didn't mean to hijack the thread, just good info.
TW
TW
TW
TW
They will fit all other '94 - '97 Accord models without problems. A 205/60x15 Tire will fit every day of the week.
P
