How much torque for spark plugs?
Old Aug 8, 2002 | 08:26 PM
wessieball's Avatar
Default How much torque for spark plugs?
Just curious. I don't have a torque wrench so I finger-tightened my spark plugs until I couldn't tighten them anymore and then I turned them almost 1/2 a turn. Does that sound right? The manual specifies 2/3 turn but somebody on the board said 1/2 turn is fine (I'd rather go a bit too loose than too tight). Are they too loose/tight?
Old Aug 8, 2002 | 08:45 PM
sgT's Avatar
sgT
Default Re: How much torque for spark plugs? (wessieball)
1/2 turn is fine for new plugs only.
2/3 wouldnt hurt either so do whhichever you are most comfortable with
Old Aug 9, 2002 | 01:43 AM
PyroVTEC's Avatar
New User
Default Re: How much torque for spark plugs? (sgT)
Go w/ the two-finger rule. Use only two fingers on the ratchet (index & middle fingers), and turn as hard as you can with your fingers (don't pull back w/ your arm or wrist though!) to secure the spark plugs. Unless you're some overmuscled redneck, this rule works well enough so that all but the strongest people can properly torque spark plugs.
Old Aug 9, 2002 | 02:19 AM
kinesistech's Avatar
Default Re: How much torque for spark plugs? (PyroVTEC)
Uh? Sure, the book says finger tight then 13lb.ft.
Old Aug 9, 2002 | 09:27 AM
PyroVTEC's Avatar
New User
Default Re: How much torque for spark plugs? (kinesistech)
Finger tight means "as tight as you can turn the spark plug/bolt/screw/nut/etc. with your hand."
Add a ratchet with two fingers 2-3" from the fulcrum (pivot point of the ratchet); that's more than finger tight.
Use a torque wrench and you'll see that the two-finger rule is around 10-12lb/ft.
Old Aug 9, 2002 | 10:16 AM
tk's Avatar
tk
15ft/lbs with anti-seize
Tom...www.tkmotion.com
14 NHRA Records...Porting...Flowbench
Making the fastest cars faster!
jvr
Apr 26, 2014 02:24 AM
mynameizstitch
Jun 22, 2009 08:32 PM
JDMfrontedLS
Mar 30, 2006 09:11 PM
Flux
Jul 29, 2002 09:46 AM
paulyman
May 20, 2002 07:11 PM
