EM1 stereo bezel question
Ok, first off, I did search the stickies and Im suprised theres not one in there about this.
Whats the trick to gettin the stereo bezel out in an 00 Si Civic? The top part is loose, but the middle and bottom dont want to come out... and I really dont want to break by tuggin on it.
And YES I did remove the 2 screws at the bottom....
Any help is much appreciated!
i use a pick, i bent it at ninety degrees and i used that to pop the bezel out. never broken one. my car was broken into and the bezel cracked... fing sucked trying to find a replacement.
when mine was broke into those were torched out. so when i test installed my new one i didnt screw those in and its holding perfectly. i never screwed them in because i have had to pop it on and off a lot with my wiring for subs and all.
Thank You Sir!!! Those 4 bolts would be the reason that it wont come out hahaha... Now I can finally put my head unit in!
Mar 31, 2002 08:38 PM
