bearings on the crank
Old Aug 8, 2002 | 08:05 PM
Leimokei's Avatar
New User
Default bearings on the crank
The machine shop has just finish polishing up my crank, now they took the bearings out of the crank and do not know where they are, i had called honda and they said the bearings are color coded and they're not universal...does anybody have the size chart that matches the 7 different color coded bearings on the crank...and also on the rods...thanks...
Old Aug 8, 2002 | 09:08 PM
Leimokei's Avatar
New User
Default Re: bearings on the crank (Leimokei)
this is for a B18B block
Old Aug 8, 2002 | 09:25 PM
IN VTEC's Avatar
The most accurate way of determining proper bearing sizes (since you had them polish it) for your selected clearances is to mic it. Since the journals were polished, it might have taken off enough to loosen up the tolerances too much, given that the journals already had wear & tear on them and then were polished on top of that. I would not assume the same as original bearing sizes.
You can also plastigage it, but that's not as accurate or precise.
Old Aug 8, 2002 | 09:37 PM
Leimokei's Avatar
New User
Default Re: bearings on the crank (IN VTEC)
yea exactly, i had thought about that..but the size of bearings are not the same original size anymore...but i mean this block is gonna be turboed...so we were worried about the tolerances level on it...but what they were considering doing was to resize it...we were also thinking about ordering 70 bearings..considering that we need about 10 bearings and there are 7 different color code...i
Old Aug 8, 2002 | 11:12 PM
IN VTEC's Avatar
It might have been worth it to just get everything machined to the same parameters so that you can use the same sized bearings for all of them.
I'll see if I can scan in the page tomorrow if I have time, or if I don't have the time for that, I'll just give you the color and bearing size.
[Modified by IN VTEC, 2:13 AM 8/9/2002]
Old Aug 9, 2002 | 06:45 AM
X2BOARD's Avatar
Get it plastigauged... physically checking the clearance will be the only sure way to do it.
Old Aug 9, 2002 | 07:35 AM
Leimokei's Avatar
New User
Default Re: bearings on the crank (X2BOARD)
yea thanks you guys...the thing is that...i want to get this done right..i don't want a bearing to come out like 10,000 mile down the road..but yea if you have the chart that be great...i really appreciate it...
Old Sep 29, 2006 | 01:24 PM
kndaqikEG's Avatar
I definitely wouldnt recommend buying 70 bearings!!! They cost approx. 12$ a piece!!! meaning 24$ per journal!!!!! Do the math, its not gonaa be cheap.
D.Dappa
Jul 16, 2007 01:57 PM
acrocat
Jun 15, 2007 06:34 AM
pcguy760
May 11, 2005 09:48 PM
SHhh__VTEC
Jun 2, 2004 11:19 PM
jisu009
Jan 26, 2004 04:13 PM
