Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Quick si Quesiton
Old Feb 10, 2009 | 09:24 AM
Nomial17's Avatar
Default Quick si Quesiton
Sorry, I was looking aroiund the site and couldn't exactly find the answer i was looking for, so could anyone tell me how much HP the si has BEFORE vtec kicks in?
I was thinking it'd be in the 150-160 range?
Old Feb 10, 2009 | 10:32 AM
Zeusone's Avatar
Default Re: Quick si Quesiton
look at dyno charts. it varies by car and dyno, etc.
Old Feb 10, 2009 | 12:43 PM
RICO_'s Avatar
NO MERCY!
Looking at my chart it's about 112whp to 123whp between 5000rpm and 5800rpm. But that's on a Mustang Dyno with a factored 20% loss to the wheels. So at the flywheel it's about 140 - 154HP.
Old Feb 12, 2009 | 10:03 PM
inkong's Avatar
i think whp is more important to consider ... looking at a stock k20z3 i believe that 123whp is alittle low but vtec does make a difference ... good luck looking for a stock dyno chart
Old Feb 13, 2009 | 02:21 AM
RICO_'s Avatar
NO MERCY!
Yes I know that. I was just giving the guy the answer he requested.
And the power below Vtec is low for a reason. Believe it or not even though the Si is the performance flagship of the Civic line...it was still designed with fuel economy in mind.
Old Feb 13, 2009 | 06:12 AM
inkong's Avatar
well thats nice to know, i always considered the Si to be more then just a fuel economic vehicle ... but all k20s have I-Vtec which includes the VTC fuction so i guess its kind of obvious ...
Old Feb 17, 2009 | 01:47 PM
FA5Clown's Avatar
this is a lil off subject but relevant to fuel economy, if im doing driving and its hilly and i better off stayin in lower gear meanin higher rpm and more power? or should i leave it in higher gear meaning lower rpm and less power but better mpg? btw im aiming for mpg.
Old Feb 17, 2009 | 01:55 PM
K5^'s Avatar
K5^
Brand New
Lower gear higher rpm.
You don't want to put too much load on the motor especially when going up hills. Imagine riding a mountain bike uphill in higher hear and how hard it is pedal. Now take the same scenario but in lower gear, you pedal faster but with less effort.
The little extra fuel you burn while in lower gear doesn't compare to the excess wear you'll undoubtedly put on your motor if you keep it in higher gears when climbing hills.
Old Feb 17, 2009 | 03:51 PM
ChargedSI's Avatar
In reviewing my Dyno's (Dynojet), the WHP looks like it peaks at around 124/125 from 5,200 to Vtec (5,800), then jumps to around 168 from 5,800 to 6,700, then climbs to 189 from 6,700 to 8,200.
Course, everyones car is different.
Old Feb 17, 2009 | 04:27 PM
Nomial17's Avatar
^^ This my friend is very helpful and probably true for most cars as a general guidline. On the other hand for the Si as Fuel efficient...kinda laugh haha, being that the Si is the performance version...I drive it like the performance version...I can say my fuel economy is...."lower"
Old Feb 18, 2009 | 11:55 AM
FA5Clown's Avatar
thats what i was thinking but i seem to be getting better mpg in 6th? the hills arent too steep so thats possibly why? when i drive i usually try to equate it to riding a bike, which is why i usually kept it at a higher rpm but if im gettin better mpg is it really "harder" on the engine?
Old Feb 18, 2009 | 12:34 PM
teggsr925's Avatar
is that stock? cant be
Old Feb 18, 2009 | 01:06 PM
ChargedSI's Avatar
Crap, your right. The dyno I was looking at has my Greddy Evo 2 Catback and AEM Cold Air. Can't find my bone stock Dyno, hope I did not lose it.
Sorry for the mis-information, I thought this was my stock Dyno.
Old Feb 18, 2009 | 01:52 PM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Check out where peak torque comes in and try and stay above that when going up hill. For instance my MS3 gets full torque at 3k so I keep it right above 3k so that I an not lugging my motor.
Lugging you motor = bad whether its going up hll or just going an a flat road.
Old Feb 18, 2009 | 02:46 PM
teggsr925's Avatar
still good to know tho
Old Feb 19, 2009 | 08:55 AM
FA5Clown's Avatar
well if i were to have my rpms where the torque peaks, since its a honda i would hafta be in vtec which i know is unnecesary.
Old Feb 19, 2009 | 12:44 PM
clemsonhatch's Avatar
Bone stock 07 Si:
Old Feb 19, 2009 | 12:51 PM
Lugging you motor = bad whether its going up hill or just going an a flat road.
The torque is pretty even across the range. Peak torque is after VTEC engages, I wouldn't recommend driving at 6000+rpm to save gas.
Old Feb 19, 2009 | 01:54 PM
K5^'s Avatar
K5^
Brand New
Also look in your manual, it lists road speed shift points. Each speed provides a shift point right at 3k, that way you stay in the torque curve while keeping revs low.
Old Feb 20, 2009 | 09:56 PM
FA5Clown's Avatar
i bought my car used and i didnt notice i didnt have the manual til after i left but basically keep it around 3k for cruising?
Old Feb 20, 2009 | 09:59 PM
K5^'s Avatar
K5^
Brand New
Make sure that after you shift you land at least above 2300. Look at the graph above. Just make sure that you're in the torque curve so you don't excessively load the motor.
Old Feb 22, 2009 | 07:11 PM
ajpturbopittsburgh's Avatar
Originally Posted by clemsonhatch
Bone stock 07 Si:
Wow the car only lost 6 hp and 2 ft/lbs or torque to the wheels.
Really?
Old Feb 22, 2009 | 07:13 PM
i-VTEC_DOHC's Avatar
yea really.
Old Feb 22, 2009 | 07:16 PM
doubt it. I've seen your posts....You should know better
Old Feb 22, 2009 | 07:22 PM
hahaha i was messing with you.
usually its around mid 180's.
the car might have had an intake or something.
but i've seen a stock si pull those numbers as well.
but it was on the dyno at sea level during the winter.
and what do you mean you've seen my posts??
