96 accord clutch issues
Old Feb 9, 2009 | 06:24 PM
christ0pher's Avatar
Icon2 96 accord clutch issues
OK i got a 96 accord lx with 190k. I don't know if this clutch has ever been replaced seeing i just purchased the car however the clutch petal seems stiffer than normal and if u try to speed shift the car it just slips. The petal seems to be letting out out the very top... if you barley touch the clutch petal while driving it slips. I was thinking about just putting a new clutch, pressure plate, and throw out bearing in the car but, should i go ahead and replace the slave and master cylinders? or should i start there before the clutch?
Old Feb 9, 2009 | 06:52 PM
P_Adams's Avatar
Default Re: 96 accord clutch issues
You need a new clutch assembly
Clutch Disc - (1)
Pressure Plate - (1)
Throw-out Bearing - (1)
In effect the Clutch disc has worn to the point that the Pressure Plate is JUST to the point of loosing clamping force. That's why it releases so high on the pedal travel.
If the clutch fluid looks dirty, brown and cloudy, It might be a good idea to replace both cylinders. The discolored / cloudy fluid indicates water mixed in. This can (and does) corrode the cylinders from the inside.
Have you ever had a Brake Master cylinder fail and your pedal go to the floor?
P
acerulz
Transmission & Drivetrain
Nov 10, 2012 04:41 PM
TimKing89
Aug 12, 2010 10:32 AM
swimmer
Jun 9, 2010 02:33 PM
nikker
Mar 3, 2005 10:50 PM
ggoodspeed
May 17, 2004 03:17 AM
