How to install a pedal Stopper!
Old Feb 9, 2009 | 02:06 PM
b20vtech's Avatar
Default How to install a pedal Stopper!
Need advice on how to install one. Im having trouble getting in gears @ high RPM's after installing the tilton twin disc on my race car, was told that i might need a pedal stopper.
Old Feb 10, 2009 | 03:57 PM
b20vtech's Avatar
Default Re: How to install a pedal Stopper!
bump!
Old Feb 10, 2009 | 06:29 PM
Blown90hatcH's Avatar
Weld a couple nuts to the floor and install a bolt with a large head.
Or
Weld a nut on the clutch arm and install a bolt with a large head.
Or....
There are a bunch of options. You need a pedal stop so that you do not over stroke the clutch as it says in the instructions.
Old Feb 10, 2009 | 06:33 PM
iwanttokillgod's Avatar
let me get this straight you built a race car or drive one and you cant fathom how to build a pedal stopper
Old Feb 12, 2009 | 10:57 AM
b20vtech's Avatar
This "TECH" forum not "FLAMMING" forum! If u got something smart to say, take it somewhere else!!
Old Feb 12, 2009 | 01:39 PM
Old Feb 12, 2009 | 02:17 PM
671islander's Avatar
just curious what the purpose of this stop pedal?
Old Feb 12, 2009 | 02:19 PM
kaiba's Avatar
x2
Old Feb 12, 2009 | 03:18 PM
Many clutches require that you install a pedal stop so that you do not overstroke the clutch diaphragm spring.
Old Apr 1, 2009 | 01:17 PM
b20vtech's Avatar
Originally Posted by Blown90hatcH
thanks for taking the time!
Old Apr 1, 2009 | 04:20 PM
fcm's Avatar
fcm
Old Fart
Wait, is the clutch pedal not adjustable on your car, on my 94 LS all I did was adjust my clutch pedal. 94
Old Apr 3, 2009 | 04:55 AM
turboedsupe's Avatar
You can just use the clutch start sensor as a stopper. If you get under the dash you will see the sensor on the pedal. Just un plug it and screw it in towards the pedal
dakidd05_99
Jul 20, 2008 08:11 PM
MadCityLude
Aug 3, 2006 01:48 AM
eg6T
Apr 12, 2006 06:34 PM
cjohnson_2
Oct 15, 2001 08:39 PM
