Erattic Idle :(
Old Aug 8, 2002 | 06:20 PM
vtechatch's Avatar
Default Erattic Idle :(
Today my car developed a problem where it fluctuates from 1000-1300 while im waiting at a light.
It doesnt always do it and I noticed on my Air/fuel guage that it goes from super rich to almost stoich at the same time as the idle.
Im pissed at this car.
I noticed that my air filter blew out the bottom and was letting in dirt for god knows how long.
The car runs exactly the same as it always did.
I have only Type R Cams and springs and the type r cam gears with 4000 miles on them.
Anyone got any ideas?
Old Aug 9, 2002 | 02:56 AM
vtechatch's Avatar
Default Re: Erattic Idle :( (vtechatch)
Heeeeeeeeeeelp
Old Aug 9, 2002 | 04:05 AM
EKB18BPR3's Avatar
u need a new fuel pressure regulator...or ur fuel pump is bad....if u dont mind putting **** in ur fuel tank...try Gumout by pennsoil...its a CONCENTRATED formula that cleans ur fuel line and injectors. i use it every other tank fill. keeps my idle smoothe and good on accelerating
Old Aug 9, 2002 | 04:17 AM
311's Avatar
311
check your fast idle valve, its on the intake manifold near your throttle boddy. there is a screw that sometimes gets backed out, and that can cause your idle to fluctuate. just a guess.
Old Aug 9, 2002 | 05:02 AM
Zer0DazE's Avatar
Default Re: Erattic Idle :( (311)
also check the IAC
Old Aug 9, 2002 | 05:50 AM
deepnite's Avatar
Default Re: Erattic Idle :( (Zer0DazE)
in the end there s the O2 sensors
Old Aug 10, 2002 | 02:18 AM
vtechatch's Avatar
Default Re: Erattic Idle :( (deepnite)
I guess ill try to change the fuel filter and clean the iac and throttle body.
If that dont work ill try the spark plugs.
What else should i check and how much is a fuel pressure regulator?
My motor only has 23,000 miles thats why i dont think its the fpr,The fuel filter on the other hand has been there for 180,000 miles
Old Aug 10, 2002 | 05:26 AM
spencer00si's Avatar
maybe a dirty or bad IAC sensor
Old Aug 10, 2002 | 06:54 AM
deepnite's Avatar
180k on the fuel filter?..that sure tell s me something ..should change every 60k
1gcrazy
Classic Hondas
Jun 20, 2013 11:05 PM
dubman410
Apr 27, 2005 04:10 AM
EF8_SiR
Apr 6, 2003 01:43 PM
maxxdout
Jun 21, 2002 06:04 AM
