Front end noise
Old Feb 9, 2009 | 10:44 AM
zfreak's Avatar
Default Front end noise
I have a '93 del Sol SI that I'm trying to sort out all the problems with. It has an annoying noise when moving that changes with wheel speed. It's a "rum rum rum" sort of sound. The CV boot on the right was torn, so I assumed it was the cause. I replaced both axles with Advance Auto new axles over the weekend. The new axles went in easy, but the noise is still there. However it might not be as loud as it was.
You can make tight turns in either direction and there is no clicking. When you are driving straight and give the car a little nudge to the left, you can hear the noise increase as the weight of the car shifts.
Any ideas?
Thanks!
Mike M.
Old Feb 9, 2009 | 10:50 AM
Former User's Avatar
Default Re: Front end noise
Sounds like a bad wheel bearing. Buy a new bearing. Remove the knuckle and have a shop press out the old bearing and install the new one.
pcorad
22
Sep 1, 2014 09:23 AM
Byaaah!
Jun 11, 2007 07:26 PM
Civichatch2k
11
Aug 7, 2006 05:43 PM
Civichatch2k
Suspension & Brakes
Jul 30, 2006 09:34 PM
631 Teggy
Dec 29, 2003 07:55 PM
