Suspension & Brakes Theory, alignment, spring rates....
good combo with tokico illuminas?
Old Feb 9, 2009 | 10:02 AM
patrickstar's Avatar
Default good combo with tokico illuminas?
so i wanna go low. and i heard illuminas are good for a 2.5" drop? i have some illuminas laying around but i need some springs/coilovers. so what should i get in order to achieve this? thanks
Old Feb 9, 2009 | 11:38 PM
xd69's Avatar
Default Re: good combo with tokico illuminas?
Being as how u are inquiring about a 2.5 inch drop, i take it you want a 2.5 inch drop.
Therefore the only lowering springs that will lower you 2.5 inches are H&R race springs. They drop 2.5 in the front and 2.3 in the rear
Otherwise you need some coilovers
BTW i must warn you that the spring rate is going to be significantly higher and your shocks will wear out faster that at whatever height u have now
Old Feb 9, 2009 | 11:42 PM
bmoua's Avatar
skunk2 slip over coilovers would go great, you can go with the civic application (8kF?6kR spring rates) or integra application (10kF/8kR). You'll need to run to mid-range spring rates if your planning to drop your car under 2inchs.
Old Feb 10, 2009 | 06:09 AM
92civiceg9gsr's Avatar
8k is a pretty high spring rate for illumnas. I would say just get the H&R race springs.
Old Feb 10, 2009 | 09:13 AM
VTECIntegra9's Avatar
yeah im on 8/10k w/ illuminas and had em for 6 years. i'm amazed how well they're doing. Still working very well. But for your non-track setup try the lower spring rate if you can find it. H/R race would work so you dont have to worry about adjustment.
oh edit: wasnt on this spring rate the whole time :-P
eibach pro-kits for a few years im sure led to their longer life
then some neuspeed race
now the coils (omni)
Old Feb 10, 2009 | 02:02 PM
bmoua's Avatar
i've seen many people run mid-high range spring rates on the illuminas, in my opinion they pair very well together. I wouldn't go any higher than 10k spring rates on the illuminas. Though my room mate has 12k/10k spring rates on his illuminas and seems like the illuminas still respond pretty well, i wouldn't recommend it though.
Old Feb 10, 2009 | 08:36 PM
im leaning towards the H&R race springs right now. i asked some guys at a shop and they recommended h&r race springs too. how much do they usually cost new? thanks
Old Feb 13, 2009 | 05:32 AM
Coltmorris's Avatar
um..just look on ebay man. They used to go for 150 all day long
Old Feb 13, 2009 | 01:12 PM
bmoua's Avatar
you'll have a slight bottoming out issue for the front shocks, if you decide to go with the H&R race springs. Keep that in mind.
Old Feb 13, 2009 | 11:37 PM
is the drop too low for the front or something? what if i keep the dampening at its stiffest?
Old Feb 14, 2009 | 12:11 AM
bmoua's Avatar
Im sure that will help but its not going to solve the problem. You wont bottom out too much but its something to consider. Also, how many miles do you have on your used illuminas? How low were u riding when you had the illuminas put in.
Old Feb 14, 2009 | 12:44 AM
oh well im a careful driver. slow over the speedbumps. avoid all the rocky terrain and bumpy roads. i slow down when i see a pothole, even the tiny ones. it pisses everyone behind me off. i have somehwere between 1k-2k miles on the illuminas. i wasnt riding that low. 2 finger gap all around.
Old Feb 14, 2009 | 11:31 PM
bmoua's Avatar
you should be fine then bro...
Old Feb 14, 2009 | 11:49 PM
ahh thanks for the reassuring help.
everythingwentblack
Suspension & Brakes
Feb 1, 2010 02:31 PM
Redsun
Suspension & Brakes
Aug 9, 2005 08:04 AM
Sobe_Death
Jul 3, 2005 11:28 AM
EeeJayEight
Jun 20, 2004 11:30 PM
Jer
Jan 1, 2004 11:35 AM
