Suspension & Brakes Theory, alignment, spring rates....
SRR Coil sleeves
Old Feb 9, 2009 | 06:07 AM
Riced-EL's Avatar
Default SRR Coil sleeves
Hello H-t,
I recently found a set of SRR coil sleeves for a good deal. I was wondering if anyone has any information on them, such as specs and such. These will be going on Koni Yellow shocks. I have heard they will be a very stiff ride, which I don't mind. But my only fears, are the quality of these sleeves. Does any1 know of a comparable product to the SRR's?
Thank you
Old Feb 9, 2009 | 06:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: SRR Coil sleeves
Does the SRR sleeve correctly fit over and capture the Koni circlip on the shock body? If not (if you have to use them in conjunction with the OE-style Koni spring perches) then I would NOT use them on Koni shocks. Only use sleeves like Koni-specific Ground Control sleeves that have a machined lip to properly capture the circlip on the Koni shocks.
The bottom of the sleeve should have a machined edge like so:
PatrickGSR94
Suspension & Brakes
Mar 25, 2010 04:37 AM
kevinm1981
Suspension & Brakes
10
Jul 12, 2009 01:13 PM
redDAinteg
Sep 2, 2005 01:40 PM
redDAinteg
Aug 30, 2005 12:06 PM
SmasonGSR
Mar 22, 2004 12:26 PM
