DelSol wont start
Old Feb 8, 2009 | 10:45 PM
DelSlowmo's Avatar
Default DelSol wont start
my 95 delsol wont start, its not the battery or the fuses because they all have been checked and replaced, is it the relay that went out? please help ASAP
Old Feb 8, 2009 | 10:47 PM
Unseen Racer's Avatar
Default Re: DelSol wont start
put your car on ON. DONT TURN THE CAR ON just put the key on the ON position. listen for the fuel pump priming. if it does, then your fuel pump works. now move on to check to see if there is spark. pull out a spark plug, connect it to the spark plug wire and ground the threads on it. have some one crank the car and look to see if there it is sparking.
EDIT: ALWAYS start with the basics
Old Feb 8, 2009 | 10:51 PM
DelSlowmo's Avatar
me and my bro already checked and there is no spark but the rotor and stuff has spark
Old Feb 8, 2009 | 11:03 PM
then change your spark plugs and spark plug wires.also check your distributor cap. the copper pins may be bad
Old Feb 8, 2009 | 11:07 PM
DelSlowmo's Avatar
its not the spark plug wires or spark plugs, it worked like an hour ago but stopped when i had to replaces fuses because of a wire error, the distributor cap has power to it,
Old Feb 8, 2009 | 11:19 PM
check you main relay.
Old Feb 8, 2009 | 11:24 PM
DelSlowmo's Avatar
is the main relay under the hood or inside the car where the fuses are, both my fuse boxes came with no labels so i have to print one out
Old Feb 8, 2009 | 11:28 PM
under the dash. it is secured with 1 10mm bolt
Old Feb 8, 2009 | 11:29 PM
DelSlowmo's Avatar
how do u test it??
Old Feb 8, 2009 | 11:40 PM
use a .... damn what is it called. voltage meter?
the thing that has a black and gray screen and has a red and black pin to touch to check the voltage that it has/sustains
EDIT:http://autorepair.about.com/od/engin...nrelay_tst.htm
Old Feb 8, 2009 | 11:42 PM
DelSlowmo's Avatar
lol multimeter, okay ill give it atry
Old Feb 8, 2009 | 11:47 PM
there you go. that! also check if the main relay needs to be resoldered
EDIT: this will tell you how to test it
and how to resolder it
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/main-relay-2490241/
Old Feb 9, 2009 | 06:49 PM
DelSlowmo's Avatar
i got a whole new main relay from my friend, still doesnt start
what the hell
Old Feb 9, 2009 | 06:55 PM
DelSlowmo's Avatar
i also am not getting fuel and stuff like the main relay problem, but the relays are good. because when u turn it on and it makes the whining noise then clicks, it doesnt do that but the relay is fine
Old Feb 9, 2009 | 07:02 PM
so is your fuel pump priming or not?
Old Feb 9, 2009 | 07:21 PM
DelSlowmo's Avatar
what do u mean by priming, and also could it be the fuel pump fuse under the hood? where do u get those big fuses
Old Feb 9, 2009 | 07:26 PM
do what i told you to do on my first post.
turn your key on the ON position and listen. you should hear the fuel pump prime at the back of the car. it will last for about 2-3 seconds.
check all your fuses btw
Old Feb 9, 2009 | 07:31 PM
DelSlowmo's Avatar
it doesnt prime, and i checked the fuses numeroulsy
Old Feb 9, 2009 | 10:34 PM
so you dont hear the fuel pump prime?
you also got a new relay and all fuses are good?
then you might need a new fuel pump. or MAYBE the wires to the fuel pump, some how got disconnected or a ground is bad.
check your fuel pump
Old Feb 9, 2009 | 10:39 PM
DelSlowmo's Avatar
u know where the wires to the fuel pump or located? and what ground could be bad?
Old Feb 9, 2009 | 10:49 PM
i sure hope i removed the right stuff and left what needed to be left on
Originally Posted by Emshhh
Step 6: Walbro Internal Fuel Pump Installation [/b]
--> First things first, you need to un-hook both negative/positive cables from the battery to be safe, cus life is better then death.
--> Next, fold down your back seat using the key lock located on your rear speaker pannel above rear seats. There is one bolt that is holding your backseats onto the chassis which is accessible through the trunk of your car. Feel free to get all the way in your trunk to ge this bolt with a wrench in hand.
--> Once that bolt is removed, go back to the inside of the car. Push the top part of the back seat back into it's locked position so you dont have it all in the way. Pull up toward you on the back seat farthest from you, you will see two metal clip that hold the front of the seat in position. Simply mouever the clips of out their holes and the back seat should come free to take out of the car.
Seat removed. Look at all that lost change! You'll find some wierd **** under your seat lol.
--> Now that you have the fuel tank access cover exposed, it's time to release fuel tank pressure. to do this, you should open up your gas cap, as well as relieve pressure from your fuel filter. Make sure you have good ventalation so you dont start tripping off gas fumes.
--> It's time to take of the access cover, simple unscrewing of 4 screws will do the trick.
with the cover pulled up
--> Pull out the cord from the connector first
--> use a rachet to loosen the banjo bolt (prepare for small fuel leak, have rag on hand) as well as pull vaccum hose off of the nipple. Lastly, there will be 6 nuts that hold down the cover plate, remove those.
--> NOw you are ready to pull the fuel pump out of the gas tank. Pull up and at a diagonal to remove it, should just slide out like so.
--> Once you have it out of the car, it's ready to swap the old fuel pump with the new walbro fuel pump. using a flat head screw driver, gently pop off the green "safety clip" that is holding the wire plug together. Once you poped it off, unplug the connector. Make sure not to lose the green safety clip because you will need it again to reinstall.
--> Using plyers, pull the rubber hose off the nipple. NOw the fuel pump is free to come off the mount, just pull on it and it should come off( it may feel hard to come off, but that's just cus the rubber bushing makes it have a tight fit.)
--> Compare your new walbro to your Oem fuel pump to make sure everything looks the same. In my case, the company i ordered from did not send me the correct filter to for my application, so I had no choice but to re-use the stock filter.
--> For reinstallation, just do all removal backwards. snap fuel pump into mount, connect rubber hose to nipple, plug connector back into place, snap "safety clip" onto the connector, slide fuel pump down and diagonal into fuel tank, hook up rubber hose, tighten banjo bolt, plug wire connector, tighten 6 nuts to fuel plate, screw down fuel tank access plate back down tight, clip back seats back into chassis, tighten back seat bolt. COMPLETE
EDIT: YES!!! i did it right!
Old Feb 9, 2009 | 11:35 PM
DelSlowmo's Avatar
thanks mannnn but one problem... i have a del sol, so it is totally different.. hahaha **** man
Old Feb 10, 2009 | 05:41 AM
rSol93's Avatar
The fuel pump might be located under neath the rear bins. There should be an access panel once you remove the bins. The fuel pumps will probably look 99% the same as the one above. So you can probably use that process of swapping the pumps.
Old Feb 10, 2009 | 06:57 AM
hahahahahaha! sorry. ^^^^^ is correct.
but i will try to find a d.i.y thread for your del sol
EDIT: its not a detailed d.i.y, or much of a d.i.y at all but its tells you where and how
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/delsol-fuel-pump-1002075/
Old Feb 10, 2009 | 11:54 AM
spigilogan's Avatar
Had the same problem a couple of months ago, problem was the ICM (Ignition Control Module). Replaced that and my del sol started right up. Could be the same problem you're having.
