Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
problem in the steering wheel
Old Feb 8, 2009 | 10:13 PM
x_c i v i c_x's Avatar
Icon6 problem in the steering wheel
hi guys i have a 2003 civic my problem with the steering wheel that i change it from stock to a sport one but now when i tried to change it back i couldn't the adabter is stuck i cant pull it please tell me what should i do
Old Feb 8, 2009 | 11:51 PM
It Wasn't Me's Avatar
Default Re: problem in the steering wheel
Try spraying it with a little WD-40 and tapping it with a hammer. It may loosen enough to remove it.
Old Feb 9, 2009 | 07:12 AM
ok thanx man i'll try it
Old Feb 9, 2009 | 12:43 PM
toyomatt84's Avatar
Sanji
PB Blaster is a better anti-seize product than WD-40. WD-40 is 80% water-base, where as PB Blaster is Silicone-base.
Old Feb 9, 2009 | 09:43 PM
teamworxek9's Avatar
x2 on the pb blaster just dont get it all over the place. If the doesnt work get a 3 jaw puller.
Old Feb 9, 2009 | 10:33 PM
Indeed. It's just that WD-40 is a much more common household item.
Life savers. http://www.harborfreight.com/cpi/cta...temnumber=8832
Old Feb 10, 2009 | 12:16 PM
hey guys i couldn't find pb blaster so i found liquid wrench is it good?
[IMG][/IMG]
Old Feb 12, 2009 | 04:48 AM
hey guys the liquid wrench worked just fine
Old Feb 12, 2009 | 06:19 AM
Old Feb 12, 2009 | 07:01 AM
unevolved's Avatar
For future reference (or if anyone else has this same problem) when I had this issue at work, I put the wheel back on, and wiggling it back and forth got it off. That extra leverage was all it needed.
Old Feb 12, 2009 | 10:52 AM
skipbarber's Avatar
^agreed, you never want to take a hammer to your steering column.
Old Feb 12, 2009 | 01:17 PM
Tapping it with a hammer isn't going to cause any damage to the steering column. It's not made of glass.
Dezso3
Honda Civic (2006 - 2015)
Dec 11, 2015 08:57 AM
jdm_j03
Feb 25, 2008 09:18 PM
b00stME
Suspension & Brakes
Sep 8, 2006 02:05 PM
