B-series parts, EF JDM/SIdoor panels, SIRII Cams
ITR LSD added...
Time to clear out the garage. Lowballers don't even ask. Use common sense....
B-series
ITR LSD and 4.4 Final Drive (gsr) with brand new bearings, $70 included. $350 LSD + $40 4.4 Final drive + $70 bearings = $460, yours for $350. Willing to part FD and LSD
B16 SIRII cams, $40
Exedy 12lb flywheel for b-series, $60
Stock GSR B18c, flywheel $40
S80, GSR stock differential with good bearings $40
GSR cluster, 56,XXX mi, $30
Used GSR front and rear rotors, $30
EF
SI driver's side door panel, $20
rear cargo cover and side plastic mounting pieces, $100
front crossmember with ES bushings, notched for aftermarket headers. Notch is reinforced with a backing plate. $30
S1 small spline cable trans stock differential with 4.4 final drive and good bearings, $30
DX seats, light blue, no rips, no tears, $50 for both.
email Jon.Lee301@gmail.com
B-series
B16 SIRII cams, $40
EF
bunp for that diff...
__________________
lyzer227 for sale thread http://hondamarketplace.com/showthread.php?t=2546566
__________________
