S300 on accord is tehre difference in wiring from accord to p28 ecu ?
Old Feb 8, 2009 | 06:29 PM
JDMCRX's Avatar
Default S300 on accord is tehre difference in wiring from accord to p28 ecu ?
Can anyone tell me if the wiring is different on the p28ecu from the accord wiring ??
Old Feb 8, 2009 | 06:54 PM
twkdCD595's Avatar
Default Re: S300 on accord is tehre difference in wiring from accord to p28 ecu ?
what year accord, 1994 I take it probably by looking at your sig? I know to put the p28 in my 1995 p0a car all I had to do was swap 2 wires, a6 (EGR solenoid) and A11 (H02S heater) I think. someone correct me if I am wrong, its been a few years since I did it.
Old Feb 8, 2009 | 07:04 PM
JDMCRX's Avatar
Its a 94 accord with a f22B1 i dont even think the dis is right for this motor now.
Its a 94 accord im trying to put a p28 with s300 into the car what has to be done
Old Feb 8, 2009 | 07:08 PM
twkdCD595's Avatar
Should be the same as mine then which is also a f22b1 (p0a ecu), swap a6 and a11 for the p28.
Old Feb 8, 2009 | 07:42 PM
JDMCRX's Avatar
Ok this is puzzling me. Either my wiring diagrhams are wrong or im too tired lol.
Im beging to think possibly got a bad s300. cause it will not log in . I can up load maps to it but red light still on.
Old Feb 9, 2009 | 06:16 AM
twkdCD595's Avatar
Even without swaping the a6 and a11 pins you should still have been able to plug in the p28 with a decent based map for the f22b1 it would have ran but kicked a check engine for egr and o2 heater circuit.
Tell us more about the conditions surrounding your problems with the p28/ s300? Did you rewire anything else when doing this? you running the most current version of smanager? etc? You said you can upload a map, so I would asume your smanager shows online and your not having a usb problem?
Maybe you should go over to the hondata forum or your hondata dealer/ tuner if you dont have any luck here. I certainly dont know a whole lot so I am sorry I cant be more helpful troubleshooting your situation. Maybe some other hondata dealers here can add something.
rorik
Jul 17, 2018 01:57 PM
LeeMajors19082
Nov 5, 2016 09:41 AM
cpl rampage
May 12, 2009 04:23 AM
94accordshocker
Apr 12, 2009 02:30 PM
