light weight wheel question
Old Aug 8, 2002 | 04:51 PM
spork sport's Avatar
Default light weight wheel question
i'm currently on oem alloy rims 15X6.5, with kumho 195/55r15
say if i switch to k1 wheels, with the same tires, will i actually feel the difference of the lighter wheel??
i'm asking this, cos i got bored of the oem rim look, i want some aftermarket wheels, so if the lighter wheels actually makes a difference i can feel, then i'll pay more to get them
btw, it's a daily driver, plus alittle bit of autoX
Old Aug 8, 2002 | 04:55 PM
SioneSi's Avatar
Default Re: light weight wheel question (1.6se)
one thing for sure is you will feel better steering response with any lightweight wheel. Power wise maybe if you had a 17 inch heavy wheel then swithcing to a light weightwheel then you will feel a little bit of power gain by butt dyno,feeling the power difference in yur situation maybe very little.
p.s.; light weight wheel are always very good mods
cheers,
judd
[Modified by SioneSi, 5:56 PM 8/8/2002]
Old Aug 8, 2002 | 05:32 PM
spencer00si's Avatar
Default Re: light weight wheel question (SioneSi)
you wont feel a difference
Old Aug 8, 2002 | 05:40 PM
hybrider's Avatar
Default Re: light weight wheel question (spencer00si)
what he said
Old Aug 8, 2002 | 05:49 PM
eg6ajk's Avatar
depends on the weight difference between a wheels. I personally can tell a difference between a 12-13lbs and 15-16lbs wheel as far as accelleration and overall resonse
in some cars its very hard to tell any difference ie. stock corolla with a set of spoons and stock wheels, hardly any difference most likely due to soft ride, and little road feedback, add to that anemic 110hp motor
Old Aug 8, 2002 | 05:50 PM
fowler!'s Avatar
Default Re: light weight wheel question (eg6ajk)
Yeah, I agree. I definitely felt a difference when I switched from my 16" Volks to OEM ITR rims. Acceleration felt slower...
Old Aug 8, 2002 | 07:07 PM
d'oh, that means i gotta spend more
Old Aug 8, 2002 | 11:05 PM
2000_Civic_Si's Avatar
Default Re: light weight wheel question (PatrickEwing)
I felt a diffrence going from my stock 15" si rims of 16lbs. to my 15" volk te-37's of 10lbs. that is like making me a 5-6lb. lightr flywheel. and on top of that i alreayd have a 9ls. flywheels. holly reving!
Old Aug 8, 2002 | 11:10 PM
tFUnK's Avatar
i didnt feel faster accelerating, but i felt better brake response. btw this was from 18lb steelies to 12lb slipstreams
Old Aug 9, 2002 | 06:02 AM
deepnite's Avatar
regardless of whether u feel the difference of not, there is an increase of forward power..as for lateral performance it d depend more on the tire
Old Aug 9, 2002 | 06:45 AM
tonyxcom's Avatar
Default Re: light weight wheel question (deepnite)
Just dont forget about Tire weight.
My 15" Circuit8/Azenis setup is slower then my 16" Slipstream/Parada setup.
I can tell in both acceleration and braking response.
huge230
Apr 28, 2007 06:52 PM
abercrombemonkey
Nov 3, 2005 12:20 PM
Autoforma
Sep 19, 2005 09:40 PM
Philbert
10
Feb 22, 2004 11:34 PM
onesojourner
May 27, 2002 06:22 PM
