D15B7 Compression
well, when i did mine recently it read 170 on my good cylinders. (145 on my bad one). I did the math, and if i did it correctly it should be 160, but anything there or higher should be fine. as long as they are all within about 10 psi of each other your doing alright.
170, 92, check, civic, compression, compresson, d15b7, honda, psi, psicompression, reading, readings, spec, specs, test
