Does powdercoating brake calipers cause them to "trap" heat?
Old Feb 8, 2009 | 02:05 PM
ergo cogido sum's Avatar
Default Does powdercoating brake calipers cause them to "trap" heat?
A shop that had coated my JDM Type R header with a heat barrier coating had also recommended a heat dispersal coating for brake calipers to dissipate heat energy built up from hard braking, to aid cooling. He recommended against powdercoating, saying the powder treatment would trap heat in the caliper and not allow it to dissipate freely. Unfortunately, the coating he offered only came in a sort of dull greasy grey color. Are there any coatings out there that would offer the same quality and variety of colors as a powdercoat, but would have better heat dissipation qualities? My car is a daily driver that I use for weekend autocross, and I am prepping the car for the all-Honda Fastbrake brake caliper upgrade.
Old Feb 8, 2009 | 02:24 PM
teamworxek9's Avatar
Default Re: Does powdercoating brake calipers cause them to "trap" heat?
Just have them replated in the gold zinc, most newer calipers come in from the factory.
Old Feb 8, 2009 | 09:37 PM
Electroplating.. how durable is it and how well does it hold up to high temps? And what other colors are available? At the very least, is black available?
Old Feb 9, 2009 | 09:26 AM
k-series's Avatar
Brembo and Wilwood coat their calipers. Can't be that bad.
Steve
Old Feb 9, 2009 | 09:45 PM
Noticed that. But is that a special high-temp paint, or a much thicker and potentially heat-trapping powdercoat?
jdmbm
Paint and Body
Aug 1, 2014 06:32 AM
NegativeLift
12
Mar 23, 2011 04:40 AM
Fatty_1775
Jul 6, 2006 02:00 PM
