some B16 turbo parts
Old Feb 8, 2009 | 12:41 PM
Garage 808 Hatch's Avatar
Default some B16 turbo parts
FS
would like to get 1500 for everything
Manley turbo tuff B16 rods (slightly used)
arias flat top 81mm pistons with upgraded wrist pins (slightly used)
new 81mm arias rings
new acl main, rod and thrust bearings
balanced B16a crank
arp main and headstuds for B16(slightly used)
also have a sleeved 81mm b16 block from GE. it cracked the outer webbing/block. sleeves are undamaged, motor still ran perfectly, intercooler was leaking a small amount of water into the piping. I cleaned it, ground it out a bit and JB welded it. since that, it wnet through a few heat cycles and a dyno session, no leaks
Last edited by Garage 808 Hatch; Feb 8, 2009 at 12:43 PM. Reason: forgot to put a price
Old Feb 8, 2009 | 05:54 PM
Default Re: some B16 turbo parts
also have a b16 oil pan with -10an welded to it.
b16 timing belt
b16 water pump
b16 oil pump
b16 tensioner
all of these were brand new from honda on this build. have like 30 dyno pulls and under 10 track passes
Old Feb 9, 2009 | 08:44 AM
JonathonTheZombie's Avatar
I need the oil pan
Old Feb 12, 2009 | 05:02 PM
Bump, make offers
deckster333
Northeast (Sales)
Jan 14, 2013 06:02 AM
Spoon84
Oct 23, 2008 08:31 PM
HighRevn
Nov 10, 2004 11:49 AM
