instrument panel bulbs
Old Feb 8, 2009 | 06:50 AM
2gnarly's Avatar
Default instrument panel bulbs
I don't know if this is in the right place, so feel free to move it.
Okay, I took out my cluster because some of my dash lights weren't working. When I finally got it out, I noticed that some of the bulbs were missing. So my question is, where do I find stock replacement bulbs at? Let me be more clear, I need the set, which is, the bulb AND the black twist-luck bulb housing (which says Toshiba V-2 on the back). I've googled this and found info about replacement bulbs, not about the Toshiba V-2 twist lock housing. Someone please help me out.
Oh, and while we're here.. I'm in the market for the plastic cover piece for the gauge cluster. The previous owner got some sh*t on it that will not come off. Again, I've looked around and got nowhere with junk yards. I have a 2001 Acura Integra GS-R if that helps.
Thanks in advance.
Old Feb 8, 2009 | 07:24 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: instrument panel bulbs
There are extra spaces in the cluster that you do not need. Are you missing bulbs for the ABS, CEL, or SRS? You can get these at any Honda or Acura dealer.
Old Feb 11, 2009 | 03:08 PM
2gnarly's Avatar
Well, my oil, gas, and seatbelt lights don't work. The previous owner took the cel bulb out so the light would go off. I figured that some sockets weren't being used, but which ones? Which sockets are my oil, gas, and seatbelt? How can I tell if the bulbs blown?
Any help is appreciated.
Old Feb 11, 2009 | 03:18 PM
Dogginator's Avatar
Daisy... Daisy...
A multimeter can diagnose a blown bulb. Check for continuity.
What year and trim is your car?
Old Feb 11, 2009 | 03:33 PM
mrdeadman's Avatar
They let me pick
You could probably find the gauge piece you are looking for in the marketplace and the dealership for the bulb sockets.
Old Feb 11, 2009 | 03:40 PM
Chiito4's Avatar
this is the back side of my 98 gsr cluster if that helps to see which ones you need/don't need.
2gnarly
Lighting
Feb 8, 2009 10:53 AM
aznboistitch
Sep 1, 2006 01:34 AM
ej1 pilot
Mar 3, 2004 03:07 PM
rasta420
Nov 21, 2002 09:56 AM
CivicDXR
15
Oct 16, 2002 01:30 AM
