What is Your Brake Setup?!?! Oil filter?
Old Feb 8, 2009 | 06:40 AM
Mr. Em1's Avatar
Default What is Your Brake Setup?!?! Oil filter?
Hey guys im looking into gettin new pads and oil filters for my race motor in my 99 si. i was wondering what brake setups you guys are running on your streetable drag cars. I was also wondering what oil filter everybody was using, i was going to order a few parts today but i wanted to get a general consensus.
S
o far my only upgrades to my stock system are:
Earl's Stainless Lines front and Rear
1" Master Cylinder
How much fluid does the stock Brake system hold? i was thinking about converting to DOT5 Motul RBF 600.
So basically my questions are:
1. What Brake pads are you using?
2. What Brake Fluid are you using?
3. What Oil Filter are you using on your race motor?
Old Feb 8, 2009 | 08:01 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: What is Your Brake Setup?!?! Oil filter?
S
1" Master Cylinder
i'm using hawk HPS' in the front with drums in the rear :S.. i get bored sometimes and do hard stops from 110mph+ and they stop fine with no fading..
on my 99 civic it took about 1 bottle of motul dot 4 fluid to flush the whole system..
and i use wix filters on my race motor in my integra and it works fine!
Old Feb 8, 2009 | 08:16 AM
boostedcivicsir's Avatar
Mr. Badwrench
1. whatever pads came with my loaded calipers from my parts house. gsr brakes stock. itr 5 lug in the rear.
2. permatex dot 3 or whatever we have in the bulk bottles
3. oe. got a case of em from a friend at the dealer.
when i used to drive it ont he street, thats what i used. no longer tagged.
Mr. Em1's Avatar
i thought motul was dot 5? so it only takes 600ml to fill up the whole brake system
Old Feb 8, 2009 | 08:33 AM
ef9civicgen4's Avatar
1. stock breaks all the way around
2. valvoline dot 3-4
3. FULL oil filters
Old Feb 8, 2009 | 08:48 AM
Mr. Em1's Avatar
any of your guys using s2000 filters on your b series motors? i heard they can increae oil pressure up to 10psi on some motors compared to the regular oil filter
Old Feb 8, 2009 | 09:58 AM
rip94delsol's Avatar
I was also was also recommended to use the Honda S2000 filter because the elements inside are different from regular filters.
thats what I use and will remain using.
I havent touched my brakes yet since I do not have the hubs for the DSS axles installed yet.
Old Feb 8, 2009 | 10:19 AM
no, they also have dot 4, i do not think dot 5 is recommended for street use..
dot 4 should be plenty for autox, daily driving and however else you drive your car..
and ask yourself this, why would you want so much oil pressure? just make sure you have an oil pressure gauge to keep an eye on things and you should be fine
at high rpms the oil pressure is already pretty high, if it were any higher you could MAYBE start blowing seals? someone correct me of i'm wrong
Old Feb 8, 2009 | 10:21 AM
rota92
Guest
Posts: n/a
I had a box of mobil 1 oil filters laying around so that's what I used.
I ran stock GSR fronts, stock 92 SI rear calipers with Axxis ultimate pads and a front brembo drilled rotor just for looks lol
It's really not a big deal though.
Old Feb 8, 2009 | 10:28 AM
NJIN BUILDR's Avatar
I was using Hawks on my dd/race car.I pulled the calipers off and one pad fell out and on the ground.I picked it up and there wasn't any backing plate on it,it was still in the caliper.They only had about 6k and were hardly even worn.They went in the trash and the autopart store ones went in.I don't see any reason to use dot5 in a drag car,especially if it has had dot3 or 4 all it's life.I used the last of my old oem filters and a mobil1 went on this last time.
Old Feb 8, 2009 | 02:53 PM
MLR's Avatar
MLR
Try a K&N oil filter. It's made for racing with a heavy duty canister and a high flow element that also filters great. Worked perfect for us with high oil pressures and a lot of methanol in the oil.
The best part is the nut on the end. It make taking the filter off a breeze and is already drilled for saftey wire.
Old Feb 8, 2009 | 03:28 PM
locash's Avatar
K&N here for the oil filter, you want whatever oil pressure you can get at 9k+ rpm.
Mr. Em1's Avatar
where is the best place to buy k$n oil filters? what is the code for our motors?
Old Feb 8, 2009 | 03:37 PM
rota92
Guest
Posts: n/a
They carry them at any advance, I had a box of those too now that I think about it lol
Old Feb 8, 2009 | 04:21 PM
Mr. Em1's Avatar
word i have an advanced right down the road.
Old Feb 8, 2009 | 05:12 PM
narfdanarf's Avatar
I use the K&N I can go down to autozone and pick one up and they are always easy to take off due to the nut.
Old Feb 8, 2009 | 05:41 PM
swapit's Avatar
I use powerslot rotors all around with hawk pads.
russel ss brake lines and wilwood hightemp brake fluid
NAPA gold oil filters
Old Feb 8, 2009 | 08:54 PM
SovXietday's Avatar
I used to have stock CX brakes with stock fluid and cheapo aftermarket pads. Used to leave myself about 1/4 mile extra braking room because the brakes would fade so bad, especially if I loaded up on the brakes a bit.
I now have EX calipers up front with OEM pads and new fluid. Don't get much fade anymore, just needed the extra surface area. Both setups have drums in the rear because I'm not JDM enough to change them out.
OEM oil filters here.
Old Feb 8, 2009 | 10:32 PM
Mr. Em1's Avatar
word drum brakes are no good man, lots of fade stupid design lol. rear disc is def worth it, its easy to do and by the time you need to service the drums you should just take them off and pt on rear disc, it usually only costs a few hundred dollars at most
Old Feb 9, 2009 | 06:02 AM
Mr. Em1's Avatar
anybody else?
Old Feb 10, 2009 | 05:19 AM
Mr. Em1's Avatar
bump it up ttt
Old Feb 10, 2009 | 05:27 AM
i would lean towards goodridge lines if you haven't bought the russell's..
goodridge is the only company that is DOT approved
Old Feb 10, 2009 | 08:18 AM
Ls_dx's Avatar
K&N HP-1004 for the B and D (3593a)
Earl's brake lines ARE DOT approved, and so are Russell...
Old Feb 10, 2009 | 08:35 AM
tony1's Avatar
K&N oil filter here, I picked up 13psi oil pressure up top with one, i'm sold now. lol
Old Feb 10, 2009 | 09:35 AM
Turbo-charged's Avatar
damn really? thats pretty crazy.
