Connecting AEM wideband to S300
Old Feb 8, 2009 | 03:38 AM
Garage786's Avatar
Default Connecting AEM wideband to S300
Hello,
Just wondering what you guys use for the 'voltage offset' and 'voltage/lambda conversion table'?
Thanks in advance
-Yasir
Old Feb 8, 2009 | 07:44 AM
sander's Avatar
2.7(p/t)
Default Re: Connecting AEM wideband to S300
Do you have the voltage to lambda spread sheet that came with your wideband? You may input the variables from there in your conversion table. The offset is to compensate for different resistances in the signal wiring. you adjust the offset after you define the conversion table.
boostinCX
Engine Management and Tuning
Jan 15, 2012 05:03 AM
RA5_Prestige
Aug 9, 2011 09:08 PM
Maxime
May 30, 2003 08:19 AM
