Intercooler Piping
Old Feb 7, 2009 | 11:30 PM
b20vcrxsir's Avatar
Default Intercooler Piping
Hi I am planning to make between 600-650 HP. What I wanted to know is will my intercooler piping work well?
I have 2" Piping from the turbo to the intercooler and 2 1/4" piping from the intercooler to the motor.
The outlet on the turbo is 2 1/2". The Inlet and outlet on the Intercooler is 2 1/2".
Old Feb 8, 2009 | 12:18 AM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: Intercooler Piping
I'm making the same power. 2.75" from turbo to intercooler, and 3.00" from intercooler to throttle body. lol You'll probably need to run a little bit bigger piping.
Old Feb 8, 2009 | 02:55 AM
Legion_2's Avatar
I think you already know the answer. 2" piping is comically small. Small changes in piping diameter correspond to huge changes in volume. For example, 2.5" piping holds 60% more air than 2" piping.
I'd do 2.5'' all the way, with a 64mm throttle body to match.
Old Feb 8, 2009 | 11:26 AM
Riake's Avatar
The larger the piping, the less pressure drop. You are probably going to be on the very right side of your compressor map for that horsepower (totally depending on your turbo) using 2in piping. Why would you decrease the piping size right off the turbo? Atleast go 2.5 all the way. My actual vote is for 3in though.
Old Feb 8, 2009 | 11:48 AM
Bailhatch's Avatar
clearly 2.5" is the choice for the hot side...much cheaper and way better flow. If you can, have someone weld on a 2.75 or 3" fitting onto the other end of your intercooler and run that, if not I don't think it will hurt you too much.
Old Feb 8, 2009 | 02:26 PM
b20vcrxsir's Avatar
Where is a good mlace to get 2.5" piping for a good price?
Old Feb 8, 2009 | 03:28 PM
Bailhatch's Avatar
I got some from T1 quite a while ago. Good prices and it welded very nicely with just a wipe clean.
Old Feb 8, 2009 | 04:38 PM
kte324's Avatar
Hopefully my 2.5" piping will get me to 700whp!!
ashtons300zx
Dec 13, 2011 10:12 PM
Soon_2b_evil
Oct 12, 2003 03:04 PM
mattcalica
Jul 19, 2003 07:37 AM
