Any of u guys upgraded your brake booster?
Old Feb 7, 2009 | 09:03 PM
corchado85's Avatar
Default Any of u guys upgraded your brake booster?
What up HT my brake booster gave out on me and since i my model is a LX and i have the rear disc conversion and plan 2 do the V6 front conversion will the EX accord or V6 accord or newer than 97 accord or prelude take the brake booster and bolt on with no problem and take the same master cylinder as mine (mind you my accord is a LX it's none abs will they bolt on fine) help me out if any of you guys upgraded ???
Old Feb 7, 2009 | 09:26 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Any of u guys upgraded your brake booster?
That was quite a confusing read. If you have an LX with 4 wheel disc and it's not swapped you should have ABS as it was an option. Otherwise you should have drums on the rear.
The EX and V6 use a 1" booster if I recall and the LX is 15/16"
Not sure if they'll swap over but I'd imagine they would.
Old Feb 8, 2009 | 08:46 AM
P_Adams's Avatar
At this point (if I understand correctly), you've a 199x Accord LX non-ABS Booster / Master Cylinder assembly that has failed. This was operating a oem, non-abs Front Brake system and a rear Disc Brake conversion.
You may find that you'll have to stay within the '94 to '97 family of Accord brake systems. This is what I found:
Brake Boosters:
The Brake Booster for a non ABS system measures 8" Diam x 7" Deep
The Brake booster for an ABS system measures 9" Diam x 8" Deep.
Master Cylinders:
Non-ABS: 15/16 Piston bore Diam
ABS: 1.0" Piston Bore Diam. Reservoir larger on one example I found.
Both versions mount the same.
I can not comment on any issues you may experience with pistom depth or pushrod length. I personally have never had reason to do this. Whatever.
I hope this helps forward the discussion.
P
Old Feb 8, 2009 | 04:41 PM
corchado85's Avatar
I have n lx so that neans drums in the back but since I'm goin to upgrade to disc and found myself in the situation of needing a booster I figure ill get a ex or v6 booster the question really is since I don't need a master cylynder will my lx non abs master cylinder fit those bigger brake boosters of the v6 or ex
ColeCooper90
Feb 27, 2019 01:35 AM
