is there any A/C Write ups out there?
Old Feb 7, 2009 | 01:08 PM
starbai's Avatar
Default is there any A/C Write ups out there?
I've never done any work on an A/C system before. Theres all kindsa noise coming from my compressor and I'm not sure if it could be at tensioner or if is the compressor itself that needs to be replaced.
I did a search here on the forums but i'm not seeing anything relevatnt. Anyone have any links to writeups or any advice on what to check first and how?
I dont have to discharge the refridgerant to just take off the belt right?
How would I inspect it once the belt is off? Given my prelude's h23 I would assume the best way to tackle this is from the bottom of the car correct?
any help greatly appreciated...
tia!
Old Feb 7, 2009 | 03:04 PM
GraphiteMW's Avatar
Default Re: is there any A/C Write ups out there?
You can work on the AC compressor from the engine bay, no need to go under. But you will need to remove the PS and alternator to reach the ac compressor. You will also need to drain the refridgerant if you plan to remove the AC lines from the compressor.
Hawaiianhonda
Acura TSX
Apr 16, 2017 11:42 AM
SOHCglory
Jul 25, 2012 12:10 PM
SuM Honda
Oct 6, 2008 08:40 PM
floriudabrain
Jan 31, 2006 07:04 AM
kmar111
Jun 20, 2004 05:25 PM
