2001 Accord overheating
My 2001 accord is continuously overheating. I have replaced the thermostat multiple times. After that stopped temporarily fixing the problem, I have replaced the water pump, timing belt, and head gasket. I've had a mechanic friend work on it, and he can't find anything else wrong with it to cause the overheating. I'm tired of paying $60/hr to have it looked at by the local dealer with continued little "improvements" without a permanent solution. Please help.
Anyway, have you checked that the fan to your right is on (when standing in front of the hood) when the engine temperature goes over 40% the gauge on the dashboard?
Better yet, does the fan to your left turn on when you have the AC turned on?
It could just be a mechanical problem with the fans, themselves. That was my issue.
If you had work done to the radiator and used 100% antifreeze it could cause it to overheat, ur suppose to use 50/50. Just a thought, i made this mistake with my CRX awhile back and that caused the car to overheat.
Princess9483
Mar 8, 2013 03:54 PM
partyupy2klpl@hotmail.com
Sep 15, 2006 07:07 PM
