wiper motor won't work right
Old Feb 7, 2009 | 08:51 AM
flymy's Avatar
Default wiper motor won't work right
I have a 1985 Honda Accord and my wiper motor only runs on high,& it will stop were ever, as soon as I turn the wiper off. and will not return to the park location. The wiper motor that was on the car just locked up & I changed it with one from a scrappyard and it does the same thing.
Can anyone help me
Old Feb 7, 2009 | 10:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: wiper motor won't work right
I would check your switch, if the "new" motor does the same thing the problem has to be the switch or possibly wiring.94
Old Feb 7, 2009 | 01:30 PM
flymy's Avatar
OK How do I check the switch and or change the switch?
Old Feb 7, 2009 | 04:17 PM
fcm's Avatar
fcm
Old Fart
to check the switch you will need a multimeter and a wiring diagram.
Not sure how to change it, but it probably requires removing the steering wheel, on most, [but not all] Honda/Acura the head light, signal lights, and wipers are all in one, "Combination Light Switch". 94
Old Feb 8, 2009 | 03:12 AM
flymy's Avatar
I was talking to some one and they said that there are two diffrent models .one you have to pull the steering wheel and a hole bunch of other stuff ( he said it will be easier to just change the hole colum),the other you have to take the cover off the colum and the switch will come apart. I don't know which one I have .
Old Feb 8, 2009 | 06:26 AM
srmofo's Avatar
its not that bad to pull the switch out....easier to change the column,wtf? that thing doesnt even have airbags
Old Feb 8, 2009 | 09:51 AM
fcm's Avatar
fcm
Old Fart
Ditto the above.^^^
You will have to pull the steering wheel, the wiper switch is part of the "Combination Light Switch"...
http://catalog.autohausaz.com/autoha...6046592OES.JPG but pulling the steering wheel and replacing the switch is going to be a lot less work, [easier] then replacing the whole steering column. 94
Old Feb 8, 2009 | 04:18 PM
flymy's Avatar
I thank all of you for the replies that you gave on this blog this has been some good info. I looked on some diffrent auto parts web pages and the most commonl cost for the switch is around $190.00 . I don't know what a scrapp yard would charge but I'll find out tomorrow.
HighCardAce
Nov 5, 2009 02:35 PM
HittingOnAllFour
Aug 7, 2008 07:39 AM
ferio 95
Mar 3, 2005 04:47 AM
BeavisB16
14
Apr 2, 2004 09:51 AM
agreen
Jun 16, 2003 05:23 PM
