Smoke slowing down?
Old Aug 8, 2002 | 02:28 PM
nsxmatt's Avatar
Default Smoke slowing down?
I just put my "low mileage" b16 swap in yesterday. It had very stale gas in it and took a while to get started. Had to use auto tranny fluid to clean the cly and give it back compression. It smoked very bad at first on the way back to my house (3 miles or so) This morning I went and drove it around to try and get the smoke out. It slowly went away but after 50 miles it still smokes if you slow down in gear and accelerate again. It looks like a white tint but could be blue since i'm looking through the rear view.
The only thing no hooked up is the o2 (waiting on 4 wire) which would cause the engine to run rich but that would be a all the time black type smoke right? Anyway i'm hoping it's not rings although with my luck it will be. Any ideas?
Old Aug 8, 2002 | 02:44 PM
Spade's Avatar
Default Re: Smoke slowing down? (nsxmatt)
Rich is black. Lean is white. Coolant is white. Oil is blue.
Compression check.
Old Aug 8, 2002 | 04:13 PM
tinkerbell's Avatar
Default Re: Smoke slowing down? (Spade)
Compression check.
compression check.
t..
krazyk606
Feb 19, 2008 08:11 PM
GSR_hatch936
21
Apr 28, 2007 11:10 PM
finest_GSR
Jan 29, 2006 06:32 AM
SIK IN DA HED
Jan 6, 2004 09:24 AM
allmotor2000
May 10, 2002 01:56 AM
