type-r head on gsr block ?s
Old Feb 7, 2009 | 08:33 AM
kyleeuuu's Avatar
Default type-r head on gsr block ?s
ok so im puting a type-r head with jun valve terrain and a jg manifold and a 65 mm throttle body on to my stock gsr block and stock gsr ecu will i run to to any problems or is it plug n play
Old Feb 7, 2009 | 08:34 AM
kyleeuuu's Avatar
Default Re: type-r head on gsr block ?s
and ar all b series headers interchangeable like can a header ment for a gsr work on a type r head
Old Feb 7, 2009 | 11:48 AM
98civdx's Avatar
Master Detailer
yea im pretty they can because a gsr and type r are basicly the same motor, just diff internals.
Old Feb 7, 2009 | 12:58 PM
CivicSpoon's Avatar
You'll throw a code for the IAB (secondary butterfly), since you're not using the stock GS-R intake manifold but you're using the ECU for one. The header will also work.
Old Feb 7, 2009 | 01:02 PM
Honda_Cribb_GS-R's Avatar
i did some research and saw were that a itr head on a gsr block will lower the compression of the engine cause i was thinking about doing this to
jdmstyleEJ6
19
Apr 15, 2010 03:36 PM
killerB16A
Dec 30, 2009 06:00 PM
Cboy1-EG6
13
Jun 6, 2005 01:20 PM
Sik Wit It Hatch
Nov 11, 2004 08:06 PM
itr1236
Jul 14, 2001 09:32 AM
